Old 08-11-2009, 04:14 PM   #1
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
Glass mosaic one step method
Normally when we install glass tile or mosaic we use Laticretes 254 platinum to install the tile and then come back the next day to grout and clean joints.
Had been hearing alot about the "one step method" for a while now and i saw Gueuese's "You Tube" videos on it , so i had this 50 sq ft wall to do in a 1/2 bath and figured this was the perfect time to try it out and "wow" was i happy with the results-- a little messy but worth it, saved me about a half days work.Got a 5 gallon bucket of Laticretes 4237 and some 25lb bags of Laticrete bright white 1500 grout, (the 4237 is some seriously stickey stuff)
Did a little mock up a few days before hand just to test it out to make sure everything would be fine and
Heres some photos of the install,
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Old 08-11-2009, 04:17 PM   #2
Some more,
Steve
Old 08-11-2009, 04:19 PM   #3
And the last,
Steve
Old 08-11-2009, 04:26 PM   #4
nice! looks awesome man
Old 08-11-2009, 04:55 PM   #5
gueuzeman
4237- Yogurt. Yummmmmm.
Looks great. And no time cleaning joints from thinset bleed thru, unless you consider that it's ALL thinset bleed thru. ??
gueuzeman is offline   Reply With Quote
Old 08-11-2009, 05:17 PM   #6
pooky
pooky's Avatar
awsome
I'll never set glass mosaics any other way again
genius move
it can be such a hassle picking the thinny out of the joints like a monkey
diggin bugs of his buddy's head . . . not that there is anything wrong with that
It just makes using other colors than white and gray so much more viable . . .
latircrete kudos
"End Monkey Lice Picking Syndrom -- Use 4237"
Stephen -- Man vs. Tile -- The Battle Continues . . .
pooky is offline   Reply With Quote
Old 08-11-2009, 05:20 PM   #7
can you use the stuff and use 1600 unsanded laticrete grout instead as your thinset powder?
Old 08-11-2009, 05:27 PM   #8
MICK1
It is been done for long time in Italy I think they call it affogato or malta bastarda, and of course in the Italian tradition that are not very nice name to wish or call somebody. Gueuzeman knows his ....
Thanks.
Mick
Mick
MICK1 is offline   Reply With Quote
Old 08-11-2009, 05:28 PM   #9
MICK1
By the way some amazing stuff that 4237
Mick
Mick
Old 08-11-2009, 06:36 PM   #10
Aquera
Air Filter
Aquera's Avatar
is this method strong enough to use in a shower?
Aquera is offline   Reply With Quote
Old 08-11-2009, 07:12 PM   #11
who you callin a bastarda ?
you sure it's not.......bastardo di mortaio ?
hard as a rock and sticky too with the 4237
Old 08-11-2009, 07:15 PM   #12
Hey Steve,
great idea...where did you ever get the brilliant idea from ?
looks awesome btw.
Old 08-11-2009, 07:38 PM   #13
gueuzeman
Rick- it looks like just the sanded grout is spec'ed in the Laticeret Tech data sheet #145.
http://www.laticrete.com/portals/0/tds/tds145.pdf
EDIT- Mike- shower friendly, tough as nails, not fingernails.
Old 08-11-2009, 07:40 PM   #14
plus I dont think I would grout glass tile with an unsanded grout.
Old 08-11-2009, 07:44 PM   #15
gueuzeman
Pooky- ""End Monkey Lice Picking Syndrom -- Use 4237"
I may want to steal that for my sig line........
One step method John Dumbrille Professionals' Hangout 26 01-16-2010 07:14 AM
Glass mosaic over kerdi - One Step Method? tzalud Tile Forum/Advice Board 1 02-29-2008 10:44 AM
Best tool or method for cutting glass tile? kwh9 Tile Forum/Advice Board 3 12-06-2007 06:11 PM
Best Application Method for 1" Hex Mosaic Floor Tile. CalBear Tile Forum/Advice Board 9 09-03-2004 12:24 PM
Best Method for Cutting 1" Hex Mosaic CalBear Tile Forum/Advice Board 8 08-11-2004 04:36 PM
