Old 07-26-2009, 11:45 AM   #1
Ron Dunbar
damage to glass tile "glaze"
i have recently completed an installation of large format glass tile. the tile is manufactured by Porcelanosa, and this tile comes with a matte finish that the manufacture calls a glaze. my problem: i used white vinegar to clean up a light grout residue(which worked), but the vinegar lightly etched the "glaze" and has left some streaking on the tiles. i e-mailed photos to the factory techs in Spain, and after some days of research, they deemed the damage to be unrepairable.
does anyone out there have a solution? thank you for any advise you can give
ron
Ron Dunbar is offline   Reply With Quote
Old 07-26-2009, 06:55 PM   #2
Davestone
Florida Tile & Stone Man
I am skeptical that the vinegar made that bad of an etch unless the tile has a glaze that really shows everything.I would try cleaning with a little neutral cleaner and ammonia in a bucket of water,maybe use a stiff brush then use a towel to dry it and see what you've got.But i guess they would know better than us not having seen the tiles.
http://Davestonestile.com
Old 07-26-2009, 10:39 PM   #3
Stone Dude
wash the rest of it with vinegar to even out the finish.
Cameron DeMille
SFA, MIA
MillestoneMarble.com
Old 07-26-2009, 11:03 PM   #4
Welcome, Ron.
Can you give us an exact name for that tile?
Glass tile gives us plenty trouble hereabouts without now having a "glaze" that is sensitive to vinegar. Like to know just what that is when it comes up again.
Old 07-27-2009, 12:32 PM   #5
SABoyt
Tile, stone and grout cleaning and restoration
SABoyt's Avatar
Try making a paste with baking soda and water. Scrub the glass tiles with this using a scotchbrite pad. Then rinse with clean water and a towel.
Steve
www.HSSflorida.com
Cleaning and Restoration Services - HSMPA Certified Master Cleaner and Instructor
TMTrecovery.com
New and used Truck mounts
Cleaning and Sealing Trainer
ColorClad™ Premium ColorSeal Distributor
SABoyt is offline   Reply With Quote
Old 07-27-2009, 07:51 PM   #6
Ron Dunbar
glass tile etching
thank you all so much for your suggestions, i am working on scraps from this job. the "glaze" on this imax glass tile is not fired on. it is some kind of sprayed on matte finish. it is pretty delicate and can be easily scratched. i will try to get the factory techs to reveal the composition of this coating and the process used to apply.
thanks again and keep the suggestions coming!
ron
Old 07-27-2009, 07:55 PM   #7
dgunnels
Neesie
dgunnels's Avatar
This is good to know and could cause a postential problem for us Eco types. I actually clean with vinegar and water rather than the usual spray cleaners. Good info.
Neesie
Denise Gunnels, Realtor
http://www.harrynorman.com/agents/17291-Denise-Gunnels
dgunnels is offline   Reply With Quote
Old 07-27-2009, 07:55 PM   #8
Davestone
Good luck with that.If possible i would just redo the bad ones,you would never be able to duplicate a factory,probably baked on finish,if they would even tell you how,or give you the product.
Installing glass 1"x1" tile Didz Tile Forum/Advice Board 10 06-27-2009 01:11 PM
10 x 10 tile, "made in USA" & "BWP" pitterpat Professionals' Hangout 2 10-14-2006 04:41 AM
1" x 1" glass mosaic tile Farmer Tile Forum/Advice Board 8 06-07-2005 07:39 PM
Glass tile & porcelain - 1/8" vs. 1/4" dubliner Tile Forum/Advice Board 1 03-18-2005 06:25 PM
Anyone used Sonoma Tile's "Tantrum" crushed glass accent tiles? edbreyer Tile Forum/Advice Board 2 10-20-2004 06:44 AM
