Old 07-22-2009, 12:55 PM   #1
Jon&Ollie
Thinset, AdMix, & Trowel Size
I'm about to go help a buddy install some 12" x 24" ceramic floor tile in a bathroom, and want to make sure we're off on the right foot. Have read through lots of postings this week - very helpful, and great reminders. We'll spend some extra time on reinforcing/replacing/flattening the subfloor, thanks to all of the postings about that.
I've installed several floors, but the largest tile I've used is 8" x 8". What size trowel should we use for 12" x 24"?
Similar question about thinset... Do we need one of the more pricey ones? At the HD, options are:
CustomBlend: $5
VersaBond: $14
FlexBond: $27
And 2.5 gallons of AdMix for $20.
We're going with plywood/mortar/hardibacker/mortar/ceramic tile.
Cheap stuff for the hardibacker embedding, Versa or Flex (with AdMix?) for laying the tiles?
Jon
Jon&Ollie is offline   Reply With Quote
Old 07-22-2009, 01:03 PM   #2
Jon, assuming your joists and subfloor are OK for tile, I'd use Versabond to set the backerboard, then Custom's Granite and Marble mortar using a 1/2" square notch trowel. If your floor and tile backs are very flat, you could use a 1/4 x 3/8 x 1/4 square notch trowel and Versabond. None of the mortars I listed need the admix. Don't be tempted to use it anyway, it may make a good modified mortar act differently than intended.
Old 07-22-2009, 01:04 PM   #3
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
Customblend will be ok to set the backer board. Use either Versabond or Flexbond to set the tiles. No need for the admix, both Versabond and Flexbond are modified already. There is also a Premium Versabond somewhere in between those two for costs.
For that size tile, probably a 1/2x1/2 trowel. Don't forget to backbutter each tile and check a couple after setting to see if you have full coverage.
That size tile, I hope your floor is very flat!
(I see Bob is beating me to the answers each time!)
Trowel Size & Thinset Questions Carley Tile Forum/Advice Board 10 10-03-2016 11:37 AM
Trowel Size & back-buttering countryhouse Tile Forum/Advice Board 3 04-24-2009 08:21 AM
HELP!!! TROWEL SIZE & WHEN TO SEAL TRAVERTINE scottg Tile Forum/Advice Board 2 04-15-2006 06:44 PM
Thinset and trowel size robertser Tile Forum/Advice Board 7 03-23-2005 09:41 PM
trowel size between ply & cbu sparky 134 Tile Forum/Advice Board 1 12-09-2003 05:33 PM
