Old 04-14-2009, 02:41 PM   #1
marble wall tile install
Hello, can someone tell me if it's ok to install marble wall tile in bathroom with premixed thinset? The wall are painted with latex paint but are in excellent condition,no chipping or peeling.
Thank you sam
samson64 is offline   Reply With Quote
Old 04-14-2009, 02:47 PM   #2
Everyone here is going to advise you against it. Also you don't want to install the tile over a painted surface. You will have to roughen up the painted surface before you tile it.
Use a modified thinset like versabond that you find in home depot. It's a cement based product and will give you stronger longer lasting results. Just add water and mix it, it's not that big of a deal. I don't see any benefit of using premixed stuff. Mixing thinset is like making pancakes.
GabeS is offline   Reply With Quote
Old 04-14-2009, 03:52 PM   #3
premixed thinset is essentially mastic, and organic glue. it doesn't dry well behind stone because it can't breath. Scratch the wall up and use white versabond-- a cement based thinset mortar that doesn't need air to cure.
Also, only lay over drywall in non wet areas.
Jason W.
Superior Construction
Quincy, IL
Old 04-14-2009, 08:42 PM   #4
Sam, another vote for Versabond. It's better and cheaper.
Need Help -Marble Tile on Wall Install o2manyfish Professionals' Hangout 7 09-19-2006 03:37 PM
Install mirror over bathroom wall tile. mugentuner Tile Forum/Advice Board 2 03-16-2005 09:19 AM
Basic Question about Wall Tile Install kathykoontz Tile Forum/Advice Board 1 01-31-2005 08:15 PM
marble tile install Glenn the tile guy Professionals' Hangout 5 01-27-2004 01:37 PM
Marble Tile install jphavener Professionals' Hangout 12 03-23-2003 10:59 PM
