Old 03-18-2009, 08:49 PM   #1
dlas
Cutting penny tiles
Hi. I can't seem to find any good advice on this. I am trying to "simply" cut 3/4" ceramic penny tiles in half. The remaining half keeps splitting perpendicularly. Any helpful hints to prevent the part I want to keep from splintering? Thanks in advance!
dlas is offline   Reply With Quote
Old 03-19-2009, 08:42 AM   #2
Larryl9797
3 Baths - Trav Entrance - 4 Mosaics - Done !!!
Larryl9797's Avatar
Hi, Welcome !
How are you cutting?
What tool are you using?
Larryl9797 is offline   Reply With Quote
Old 03-19-2009, 10:01 AM   #3
gueuzeman
You could make a little jig (happy st.Patrick's Day ) like this to hold the round tile in place on your wet saw.
Holding the little piece with one fingertip can be tough, just don't lose the fingertip!
Might work on a snap cutter as well, dunno.
gueuze
gueuzeman is offline   Reply With Quote
Old 03-19-2009, 01:32 PM   #4
lati_cz
michal
tape the back side of the mosaic with HVAC aluminium tape. the tiles/mesh must be dry.
lati_cz is offline   Reply With Quote
Old 03-19-2009, 09:22 PM   #5
CSS
CSS's Avatar
I use carpet tape you can get at hd its clear I lay out a couple sheets place carpet tape over face of tiles easier with 2. Then cut install and peel after mortor sets. A really good blade is always important.
Robo
www.webspawner.com/users/premiumtileguy
CSS is offline   Reply With Quote
Old 03-20-2009, 07:19 PM   #6
dlas
Penny tiles again.
Thanks everyone. I am using a good old-fashioned tile nipper which is the only thing that works most of the time for cutting 1/3 off, which will likely work for my project. I could likely file off more if I need it. Any advice on what to use for that? I don't need to be that precise because I'm intending to wainscot the wall and cover the edges. I went to HD with a sample tile and tried a manual cutter which didn't work and really want to keep all my digits intact so avoiding the wetsaw - a contractor friend used one with his pennies but he's a bit handier (or maybe just crazier) than me. One thought is that potentially if the tile nippers came wider than 5/8" (which I haven't found) then perhaps they wouldnt split the tiles at 3/4" diameter? Does that make any sense? Cheers.
Old 03-20-2009, 07:50 PM   #7
harleysilo
DIY'er
I'd be interested in hearing some stories, cause I don't see how you could cut off a finger with a tile saw.
Nathan
DIY Homeowner
harleysilo is offline   Reply With Quote
Old 03-20-2009, 07:56 PM   #8
dlas
I just don't trust myself. Anyways, I just wanted to post my "eureka" moment. I just set the nippers off to one end of the tile 1/2-way through and it splits near-perfect everytime. I feel pretty silly at this point but thank you all for your advice.
Old 03-21-2009, 06:58 AM   #9
gueuzeman
Glad to hear the snips work, which is not really a surprise. They can take some getting used to to get the feel of them, and are a workout for the forearms.
gueuze
Old 03-21-2009, 07:14 AM   #10
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Dlas,
For exposed cuts using your nippers, pre-score the glaze using a glass cutting tool. With the glaze scored, the tile should snap with a much cleaner line.
Best of luck,
Shaughnn
penny round advice remodelingmom Tile Forum/Advice Board 3 01-21-2009 01:16 PM
Spectralock and penny mosaics HS345 Professionals' Hangout 7 08-22-2007 09:51 PM
Penny Rounds On Shower Walls anak Tile Forum/Advice Board 10 05-23-2006 09:40 AM
Setting penny-round mosaic John S. Tile Forum/Advice Board 7 01-15-2006 11:22 PM
Penny Tile mik Tile Forum/Advice Board 1 01-02-2006 02:44 PM
