Old 03-10-2009, 07:00 PM   #1
Kerdi and Noble Niche
Hi all,
I have what I hope is a simple question. I am redoing a tub surround with Kerdi and am interested in using a Noble niche vs a niche from scratch. I saw in The Kerdi Shower Book that John has used Kerdi with Noble niches. The Noble site states that modified thin set should be used to lay tile in the niche but the Kerdi installation prefers unmodified. Would it be best to use unmodified on both?
m_overman is offline   Reply With Quote
Old 03-10-2009, 07:54 PM   #2
muskymike's Avatar
Hi Mark, welcome! If you can git your hands on some Versabond usually found at Home Depot, you can use that for everything.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Old 03-10-2009, 09:17 PM   #3
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
You dont have to put kerdi on the inside of the niche, its already waterproofed
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Noble Niche Problem mjanderson Tile Forum/Advice Board 6 02-27-2009 06:36 PM
noble niche and kerdi install....can they mix? slayer73 Tile Forum/Advice Board 6 04-01-2008 04:14 PM
Noble niche melting? smhnd Tile Forum/Advice Board 29 09-13-2007 09:07 AM
Kerdi shower and Noble niche bikemike Tile Forum/Advice Board 6 05-02-2007 05:59 AM
Noble ProForm Niche curtisb Tile Forum/Advice Board 1 01-06-2005 09:13 AM
