Old 02-25-2009, 02:17 PM   #1
msenkpiel
Grout Mixed with Sealant
Hi,
A guy at a tile store told me about a sealant that could be mixed with the grout instead of water. I thought about it later when buying grout and sealer, but couldn't find any info on it.
Has anyone ever heard of some such and if so, recommend it?
Then I thought, why not just mix regular sealer with the grout instead of water? Is this a really bad idea? What might be the fallout from such bold ignorance?
msenkpiel is offline   Reply With Quote
Old 02-25-2009, 02:28 PM   #2
Read the bottle and bag of the products you intend to use. I'll wager you'll not find this kind of instruction from the manufacturers. There are a number of reasons for this, among them, they won't know whose products you intend to mix and match, unless it's theirs, and portland cement based grout needs water to hydrate. Sealers would mess with this important chemical reaction.
Old 02-25-2009, 02:49 PM   #3
astrojeff
Bob is absolutely right. Cement products cure via a chemical reaction with water. Anything you mix in that is not specifically approved for mixing with uncured grout should not be added! Especially non-water based things, such as most sealers. There are some types of latex admixtures that work fine to mix in with grout, as latex is water based. Those do have certain "sealing" properties for the final cured grout, but I have heard that they give inconsistent results, and I have never used them.
Just about anything that typically requires multiple steps is like that for a reason, and any "single-step" miracle compound is almost universally inferior (e.g. Shampoo + conditioner in one, or stain and varnish combined...etc.). Otherwise, nobody would buy multiple step compounds in the first place.
Grout, cure, then seal. Or use an epoxy grout, such as Spectralock, which is basically a plastic-like base that never needs sealer. But you pay a lot more for it.
-Jeff
astrojeff is offline   Reply With Quote
Old 02-25-2009, 03:20 PM   #4
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
The Guy at the store may have been referring to a grout additive called 'Boost" which you use instead of water.
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Old 02-25-2009, 04:28 PM   #5
"grout boost" is one additive.
Laticrete also has a grout additive, it doesn't really seal it, it just makes it dry color correct.
Anti-Hydro has addmixtures you can add to cement grouts to seal them and also waterproof the grout.
Grout Boost: Efflorescence Throughout New Home Karri Cleaning, Restoration and Sealing 20 05-11-2010 12:41 PM
4 sealant applications, grout still looks like it absorbs water! skiadct Cleaning, Restoration and Sealing 21 08-22-2006 09:12 PM
Laticrete says use Sealant in lieu of grout??? MomTo2 Tile Forum/Advice Board 10 07-19-2006 09:20 AM
My very real nightmare, help needed. YouRockDaddy Cleaning, Restoration and Sealing 11 03-09-2005 09:08 PM
Is grout protector also a sealant? nobthebuilder Tile Forum/Advice Board 4 12-12-2004 10:58 AM
