Old 12-15-2008, 08:10 PM   #1
thefed17
Jason
Difference between Laticrete Multipurpose & Laticrete Spectraset?
The only difference I see based on the bags is that Spectraset is a "premium' modified mortar....and it cost $28 a bag vs. $12.
I'm using this on floor over hardibacker, 12x12 porcelain. I've seen the comment that Spectraset works well on porcelain....why so?
www.ayden.biz
Akron, OH
thefed17 is offline   Reply With Quote
Old 12-15-2008, 08:27 PM   #2
Brian in San Diego
Brian in San Diego's Avatar
Jason,
Because of the additives added to the mortar that give it better adhesion qualities.
Old 12-15-2008, 08:43 PM   #3
Looking at the data sheets, there isn't much difference in their uses. The Spectraset has a stronger shear strength on porcelain. 340-370 psi to 250-300psi for the Multipurpose.
The Latacrete ad to the right has all that info.
Old 12-15-2008, 08:48 PM   #4
thefed17
Jason
and the shear strength would mean.....
www.ayden.biz
Akron, OH
Old 12-15-2008, 08:55 PM   #5
The Kid
The Kid's Avatar
Shear strengh would be in plane movement in relation to the substrate. I would use the higher modified with the porcelin, which is known to have problematic bonding issues.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
