Old 12-04-2008, 02:15 PM   #1
JeromeM
2"x4" tumbled Marble subway tile install question
We have these 2"x4" tumbled marble subway tiles that come in 1 sq. ft. sheets. I am just wondering about how you make the cuts?
Here's a picture for reference, I used finishing nails to hold it up, lol
Specifically around wall outlets, my thought was to dry lay the tile over the area, mark the individual tiles where they need to be cut, pull them off the mesh they are glued to, make the cuts with the wet tile saw then put them back on the wall.
If this is what people normally do, do you cut out the mesh before putting the cut tiles on the wall or do you just add more mortar on top of the mesh?
And you can see where the 2 sheets match up you have to interleave the mesh and tiles, this is hard enough to do without mortar on the wall, do you leave the mesh on here too?
Lastly, do you backbutter the wall tiles like you would a floor tile?
Jerome
JeromeM is offline   Reply With Quote
Old 12-04-2008, 04:59 PM   #2
Lazarus
Lazarus's Avatar
Yeah, just cut the mesh and make your custom cuts for the outlets with a wet saw. Put some "Pookey" on the back and set them in place. You might want to invest in some "TileSpikes" that (shameless plug) are advertised here. They certainly make the job easier.
Laz...
“Everything in excess! To enjoy the flavor of life, take big bites. Moderation is for monks.”
Old 12-04-2008, 05:02 PM   #3
your going to need to get a small wetsaw to make the cuts.
also you might want to run the same tile long ways going up each edge as a finished edge.
like on this thread.
http://www.johnbridge.com/vbulletin/...ad.php?t=57731
Old 12-04-2008, 05:10 PM   #4
JeromeM
I have a small wetsaw already so that will be perfect, and thanks for the link I will do it that way. I was going to use a metal piece on the edge but this will look good.
Jerome
Old 12-04-2008, 05:32 PM   #5
Hi Jerome,
That's gonna look sharp. They're not subway tiles, though. You gotta go down to New Yawk and go underground to see subway tiles.
Old 12-04-2008, 05:32 PM   #6
a metal edge piece would also look good as a finish edge.
Old 12-04-2008, 05:33 PM   #7
JeromeM
LOL Thanks John!
Jerome
