Old 10-18-2008, 10:15 PM   #1
larrylou
mud work
quick question for you guys do any of you flat trowel your mud after you rub it up. we dont use deck mud on counters. all fat mud and i have found it works really well to smooth it out after rubbing it up we used to just rub it up and scrape the mud the next day with a tamberine scraper.
larrylou is offline   Reply With Quote
Old 10-18-2008, 10:36 PM   #2
John Corley
John Corley's Avatar
I always rub the mud down with a wood float, then burn it with a flat trowel. So for us, the answer is yes
John
John Corley is offline   Reply With Quote
Old 10-18-2008, 10:40 PM   #3
v10ford99
I use deck mud for the counter top and I do flat trowel my mud when I'm done. So I can set the same day with out ripping my deck mud up when I put the thin set down. But on fat mud If you flat trowel it to much you will bring the water to the top and just have a mess the top will be to wet to set the same day.
Alex
R.H. TILE & STONE
v10ford99 is offline   Reply With Quote
Old 10-18-2008, 10:59 PM   #4
Crestone Tile
Gonzo!
Most of the time, yes ... especially when the mud is going have a trowel applied membrane over it.
Matt
"Shut it down!"
Crestone Tile is offline   Reply With Quote
Old 10-18-2008, 11:24 PM   #5
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hi Larry,
I use a fiberglass darby to work out my floats, instead of a wooden one. Dry pack always gets a steel trowel finish and wall mud never does.
Shaughnn
Old 10-19-2008, 06:35 AM   #6
Davestone
Florida Tile & Stone Man
I do that too, i tamp down the drypack before i pull it on large floors.Which i never do anymore.
http://Davestonestile.com
Old 10-21-2008, 06:02 AM   #7
customceramicsllc
licensed tile installation
customceramicsllc's Avatar
on the subject of deck mud,what ratios do you guys use?
John
perfection doesn't start with the tile guy
dead fish go with the flow
customceramicsllc is offline   Reply With Quote
Old 10-21-2008, 06:14 AM   #8
Shaughnn
Trowel Monkey
Shaughnn's Avatar
The Steam shower pan I just installed was Laticrete's 209 pre-mixed floor mud mixed with their 3701 admix. I normally shoot for a 4:1 mix for floors though.
Shaughnn
Old 10-21-2008, 10:31 PM   #9
Old World Tile and Marble
i like that 209 premix nice stuff to work with shaughnn where you getting the fiberglass float?? is it the one with the diamond pattern on the bottom cuz i cant find em anymore
jason
Old World Tile and Marble is offline   Reply With Quote
Old 10-21-2008, 10:42 PM   #10
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hi Jason,
I'm using a fiberglass float from Marshalltown. I bought it locally but most masonry and concrete suppliers seem to carry them.
Shaughnn
Old 10-22-2008, 12:07 AM   #11
tile dale
California Tile Man
I never steel trowel my fat mud and always steel trowel my deck mud.
Shaughnn, what are the advantages of using a fiberglass float over a wood float?
tile dale is offline   Reply With Quote
Old 10-22-2008, 06:32 AM   #12
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hi Dale,
I like the resin float because is doesn't cake up with cement and gives a finish which is close to that of a steel trowel. I haven't used a wood float in maybe 6 years now. I really like working with these that much better than wooden floats.
Shaughnn
Old 10-22-2008, 04:00 PM   #13
tile dale
California Tile Man
Thanks, Shaughnn. I'm going to have to go float shopping!
Old 10-22-2008, 04:19 PM   #14
i have a wood block i use if i accidentally dig and i fill in the wood block cuts the mud like a straight edge then i hit it with my trowel.
Old 10-20-2011, 03:53 PM   #15
Derek & Jacqui
Send a message via MSN to Derek & Jacqui
Smile Float
I use a float I get from England Made of Polyurothame (exscuse spelling) so light you would thik your hands had a feather in them
DEREK & JACQUI
NULLI SECONDUS
IMPOSSIBLE DONE IMMEDIATELY, MIRACLES TAKE A LITTLE LONGER
Derek & Jacqui is offline   Reply With Quote
