Old 09-18-2008, 09:44 AM   #1
jdjanka
Help - I got Kerdi-Fix on my stub-outs
So I got my Kerdi up and then sealed the area between the plumbing stub-outs and the drywall with kerdi-fix, but I ended up getting some of it on the threads of the stub outs. I've tried peeling it off but that stuff is so thick and doesn't come off easily - it leaves plenty behind.
My concern is that once I put my plumbing fixtures on, the kerdi-fix on the threads will prohibit a good tight waterproof connection. I was wondering if anybody had any suggestions for getting the stub threads clean for the showerhead and body jet connections?
Jason
jdjanka is offline   Reply With Quote
Old 09-18-2008, 10:03 AM   #2
Mike2
You can rent a thread chase, or make one yourself.
Are these stub-outs male or female and can you at least get something started on those threads?
A picture would help so we could see exactly what you have to deal with.
Old 09-18-2008, 04:01 PM   #3
jdjanka
Hi Mike,
Thanks for the note. The stub-outs are standard male 1/2" threaded brass - I've attached some pitchers of them. Maybe I should get a nut that would fit the threads and run it on it a few times? I'm just really concerned that no matter what, a little might be left behind and that will cause the connection to not be watertight and leak.
Thanks again!
Jason
Old 09-18-2008, 04:16 PM   #4
have you tried a hard wire brush ?
I think Teflon tape or plumbers thread dope will seal it up.
on another note........
this thread reminded me of that old Reese's commercial.
"I got Kerdi-Fix on my stub-outs"
you got chocolate on my peanut butter!
you got peanut butter on my chocolate!
Old 09-18-2008, 04:53 PM   #5
Steel coupling work better, Mikey, last longer, too.
I wouldn't worry about it much. Cut around the pipe close to the wall with a utility knife and run a war brush over them threads little bit. What stays on is pipe dope, not Kerdi Fix.
