Old 07-17-2008, 03:49 PM   #1
credwings
Trowel for 6X6 wall tile
I am installing 6X6 ceramic wall tile. What size notched trowel do i need?
THANK YOU
credwings is offline   Reply With Quote
Old 07-17-2008, 03:57 PM   #2
kurgon
WelchTile.com
I would use a 1/4" x 1/4" square notch.. after placing the tile in place and pressing it into the thinset, remove it and check for your coverage. You should see that there is thinset over 80% of the tile.
If you do not see 80% coverage on the back of the tile, step up the trowel size or your application method of how you're using the trowel.. stand it up more comb with less pressure, etc..
Ken Hyde - Welch Tile & Marble; NTCA Five Star Member CTEF Certified Contractor.
Residential - Commercial - Industrial
Ceramic - Porcelain - Natural Stone
Pools - Terrazzo - Epoxy Coatings
kurgon is online now   Reply With Quote
Old 07-17-2008, 04:00 PM   #3
custombuilt
1/4 inch and no problemo
Jason W.
Superior Construction
Quincy, IL
Old 07-17-2008, 05:09 PM   #4
Lazarus
Lazarus's Avatar
If the tiles are smooth on the back, and the walls are quite flat, you can even use a 1/8" 'U shaped' trowel. This might help keep the morter from squishing out between the tiles as you set them. As always, put up a couple of tiles and then remove them to check for a good bond. If you are using thinset, mix it a little on the "loose" side....not runny, but loose. It should hold a ridge...but just barely.
"While money can't buy happiness, it certainly lets you choose your own form of misery.”
~ Groucho Marx~
Laz...
Avanti Tile & Stone
Old 07-17-2008, 05:34 PM   #5
yup, the back of the tile and substrate would have an effect on what size trowel is being used.
........Tampa Florida Tile Installation
..................Check out our Blog
Florida Installer of Laticrete HydroBan & HydroBarrier
....Florida Installer of Schluter Kerdi & Kerdi-Board
................."Waterproofed Tile Showers"
........Porcelain - Travertine - Ceramic - Glass Tile
