Old 06-23-2008, 01:24 PM   #1
dwzemens
dwzemens's Avatar
Kitchen Backsplash Tips - This Forum Rocks!
Several years ago I completed a terrific bathroom remodel job that could not have been done without the help of this forum. I constructed and entire tiled shower unit, using Kerdi, and it came out terrific with all your help!
Now I move on to tiling the kitchen backsplash area of my son's newly remodeled home. The cabinets are in and so is the granite counter top. I would appreciate any tips on how to proceed with a mosaic tile install!
Thanks again guys and girls!
- Dave Zemens
Rochester, Michigan
http://www.1955design.com/
dwzemens is offline   Reply With Quote
Old 06-23-2008, 02:13 PM   #2
us giving you tips....that list could be endless.
probably better if you asked us a question on something you werent sure of.
Old 06-23-2008, 02:14 PM   #3
dwzemens
dwzemens's Avatar
I know what you mean, Brian. What I was really looking for was a tip or two that might relate to doing tile on a backsplash in a kitchen --- not generic advice about tiling, but something that might be peculiar to that area.
Old 06-23-2008, 02:17 PM   #4
what type of tile are you using on the backsplash ?
is there a granite 4" installed ?
do you have painted drywall back there now ?
Old 06-23-2008, 02:18 PM   #5
dwzemens
dwzemens's Avatar
I have new drywall in place. There is no 4" granite backsplash.
The tile type has not been determined yet, but likely to be tumbled travertine.
Old 06-23-2008, 02:23 PM   #6
"Measure twice, cut once."
"Never argue with SWMBO."
"Cold is on the right, Hot on the left, $#!+ flows down hill." (That last one is on the plumber's test. May not apply to your backsplash, though...
Old 06-23-2008, 02:28 PM   #7
I will start with saying to use a modified white thinset to set the travertine.
tight joints (1/8") and sanded grout will fill the joints and the holes in the tile.
seal prior to grouting and after with a sealer.
Old 06-23-2008, 07:57 PM   #8
johnnyhomeowner
what is that??
Johnny
"Dont know tile.......thats why im not a moderator"
but im learning!
johnnyhomeowner is offline   Reply With Quote
Old 06-23-2008, 08:18 PM   #9
She Who Must Be Obeyed !
Old 06-23-2008, 08:22 PM   #10
xface
when sealing tumbled travertine, do you mean seal before setting the tile and again afterward? If so, what sealant(s) would you recommend?
xface is offline   Reply With Quote
Old 06-23-2008, 08:27 PM   #11
you can do it before, but most install the tile and then apply a sealer.
then after you grout and final clean you can seal it again with a stone enhancer or a penetrating sealer.
there's a few types of finishes so you'll have to decide which you like.
you can look into AquaMix, Miracle Sealers or Dupont StoneTech
