Old 04-17-2008, 02:39 PM   #1
brer08
thin set dry time requirements
I recently had ceramic tile installed on 2 bathroom floors and tile tumbled stone backsplash in kitchen (2 days ago). I do not think the tile installers allowed the mortar to dry allotted time before grouting, as they were in hurry to finish. I am concerned as to what damage this may cause me in future. They used a thin set, powder mortar (they mixed) and sanded grout on all applications. I have not found any info on this problem. I am to seal the grout myself, but want to be careful that mortar and grout have thoroughly set. In some areas, they allowed 3 - 4 hours before applying grout, other areas, not even 1 - 2 hours. Please advise. Thank you.
brer08 is offline   Reply With Quote
Old 04-17-2008, 02:44 PM   #2
tileman2000
New England Tile Man
tileman2000's Avatar
Did they use a rapid set mortar?If not,the thinset needs a good 24 hrs. before grouting.the sealer can be applied 48-72 hrs after grouting...depending on which sealer you have.Some vary from 2 -3 days..read the label ...cheers
Michael
Old 04-17-2008, 02:52 PM   #3
brer08
very doubtful, as I heard that rapid-set is much more expensive. Just wondering what difficulties may be caused by not allowing proper dry time on mortar before grouting? some of the grout is drying with white patches in places. should I use a colored sealant to fix discoloration? thank you.
Old 04-17-2008, 03:10 PM   #4
Lazarus
Lazarus's Avatar
Assuming they didn't screw up the tile by walking on it before it "set," it shouldn't be much of a problem. In fact, if the grout was set while the morter was still curing, it'll all bond together and be quite strong!
"While money can't buy happiness, it certainly lets you choose your own form of misery.”
~ Groucho Marx~
Laz...
Avanti Tile & Stone
Old 04-18-2008, 08:19 AM   #5
esobocinski
brer (you have first name?), i wouldn't panic about patchy grout color just yet. Moisture differences will give you different shades of the same grout color. If the "white" patches are spreading as the grout dries, you might just be seeing which parts of your job are drying the quickest. It's been another day, so if this is true the grout should look rather better today.
Eric Sobocinski
DIY Junkie
esobocinski is offline   Reply With Quote
