Old 02-24-2008, 10:47 PM   #1
-Christopher
removing silicone from granite
What's the best way to remove 100% silicone caulk from granite? I've removed most of it with a razor, but there's a little bit left that the razor wont catch. Is there a solvent that's safe on granite?
Christopher
-Christopher is offline   Reply With Quote
Old 02-25-2008, 07:42 PM   #2
Davestone
Florida Tile & Stone Man
Well,it's safe for granite, but maybe not any fillers of there are any,but i don't think you'll have any problems,you might try a black scrubby pad, or try this....http://www.acehardware.com/product/i...ductId=2151183
http://Davestonestile.com
Old 02-25-2008, 08:23 PM   #3
conceptsplus
Conceptsplus- Randy Gilmore
conceptsplus's Avatar
Might try acetone. Won't hurt granite and evaporates quickly
Randy Gilmore
Natural Stone Contractor - Springfield, Missouri
Website needs updates- be back soon.
conceptsplus is offline   Reply With Quote
Old 02-25-2008, 09:03 PM   #4
Stonehenge
Mineral Polishing Education Specialist
Stonehenge's Avatar
Hi Christopher,
Before I can answer your question I require some information.
1) What is the color of your granite?
2) Where is this accumulation and/or darkening located?
Sincerely,
Michael of Stonehenge
Michael
Stonehenge is offline   Reply With Quote
Old 02-25-2008, 09:20 PM   #5
david bassler
Natural Stone Maintenance Co
david bassler's Avatar
The company called Prosoco has a silicone digest-er .
David Bassler
david bassler is offline   Reply With Quote
Old 02-26-2008, 08:25 AM   #6
-Christopher
Its Sapphire Blue granite. I removed a 4" granite backsplash to prep for a slate or quartz tile backsplash and theres the edge of silicone that was used to caulk at the plane change.
I've also been told that a nice and sharp razor does the trick without injuring the rock. I'll let y'all know what succeeds. Thanks for the responses!
Christopher
Old 03-05-2008, 02:11 PM   #7
timm sowders
Paragon Stone Care
Prosoco Dicone NC-9 and Dicone NC-15 Gel. works like a charm on all surfaces. let it sit for a while and then wipe off.
timm sowders is offline   Reply With Quote
