Old 02-19-2008, 05:23 PM   #1
jdstone
metal marks
Any advice for gettin rid of a stubborn metal mark on white wall tile? If I get one and that is rarely, I have just rubbed them out with either a little thinset or grout, but this one didnt budge.
Jim, Hillbilly Tal Mikanik
jdstone is offline   Reply With Quote
Old 02-19-2008, 05:34 PM   #2
Tileman Packerfan
Tile Contractor -- Rhinelander, WI.
I've gotten some off with emery cloth, but you really have to be careful not to dull the finish
Rob
Rob's Tile, Minocqua Wisconsin http://www.robstile.net
Tileman Packerfan is offline   Reply With Quote
Old 02-19-2008, 05:44 PM   #3
Crease
Crease's Avatar
I use WD-40 - works really well - not a joke
Crease is offline   Reply With Quote
Old 02-19-2008, 05:45 PM   #4
is it a gloss tile or a matte ?
my legs on the superior cutter used to leave little scratches.
i put the rubber boots on and it stopped.
try some soft scrub.
Old 02-19-2008, 05:47 PM   #5
jdstone
Brian,,glossy dal.
Old 02-19-2008, 05:51 PM   #6
david bassler
Natural Stone Maintenance Co
david bassler's Avatar
Jim
Are they aluminum or steel? And what is the offended tile?
David Bassler
david bassler is offline   Reply With Quote
Old 02-19-2008, 06:01 PM   #7
madronatile
Do you have a set of diamond sponges? I've removed marks from gloss white with 600. Paper might work too.
Matt
www.madronatile.com
Old 02-19-2008, 06:02 PM   #8
Splinter
Splinter's Avatar
I'll second the WD-40...
Alex
Old 02-19-2008, 06:13 PM   #9
If they're deep you'll have to remove some glaze. That's when you have to be careful about creating dull spots, which you will if you remove too much glaze.
Old 02-19-2008, 06:16 PM   #10
Mountain Tile
Tile Contractor -- Northeastern PA.
Mountain Tile's Avatar
Denatured alchohol works sometimes, sometimes you can rub the underside of a white bisque tile on the mark.
Mountain Tile is offline   Reply With Quote
Old 02-19-2008, 06:35 PM   #11
jdstone
Thanks fellers,,got a few new tricks in my bag,,
Old 02-19-2008, 07:36 PM   #12
T_Hulse
Tile Contractor
T_Hulse's Avatar
Always try a pencil eraser first. It works at least half the time and it is the least harmful.
Tom Hulse
Visit my web site here
Old 02-20-2008, 12:08 AM   #13
Deckert
Try Magic Eraser. Those little white pads that look like dense sponges.
Brannigan
HeenanGC.com
Old 02-20-2008, 01:06 AM   #14
Trask
Oregon Tile Man
Trask's Avatar
Bar Keepers Friend and a eraser also heard Goof Off works well. Unglazed white porcelian hex's and a clinker cutter are a bad combo...can't think of how many times I've done this.
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Old 02-20-2008, 07:18 PM   #15
Crease
Crease's Avatar
Oh man, I remember problems with the 1" hex. Nasty marks from everything.
Bar Keepers Friend is just oxalic acid which is the same as acid wash crystals at the tile store.
