Shop at the TYW Store
Old 08-30-2007, 09:46 PM   #1
FredF
Big Basement Challenge
All,
I'm currently refinishing my basement and am planning to lay ceramic. I'm an avid DIYer but even this project seems daunting to me.
The basement is 42' by 26'. There is a concrete slab floor that is nearly completely uniformly level (1/32 valleys here and there). The foundation has several cracks that I have monitored for some time and are not expanding (The house is 25 years old-i think major foundation movements are unlikely.
I am planning on installing 18x18 ceramic tiles; but have not picked them out. I am also planning on installing thermosoft's (TS) thermotile heating element throughout the entire basement. According to TS, this will require 4 heating zones.
The slab has no expansion joints, and I've repaired the cracks that were present. I know that I will need to put expansion joints in the tile field b/c the field is so large. Recommendations on how many expansion joints are required are welcome.
My research has told me that my best bet is to hot glue the TT mats to the slab, fill 1/4" with self-leveling mortar, and then install the tile on top of the SLM. On another thread, there is a discussion of using a ditra product to de-couple the tile from the underlying slab (i assume because the expansion coefficient of the slab and walls is different and could cause cracking.
my room is essentially a rectangle with a 6x6 utility closet in the middle of the room. Can someone help with what layers/materials I should use to get the best installation possible?
I was thinking (from top to bottom):
Ceramic
thin-set mortar
self-leveing mortar
TT product
slab
Now I think I may need to add in a "de-coupling" and "moisture barrier" layer for this to be successful.
Also, since the tile field will require expansion joint(s), at what "layer" do I need to worry about these joints? (I know that at least the ceramic and top level of thin-set will need to have the fields compleletly isolated... what about the TT product?
FredF is offline   Reply With Quote
Old 08-30-2007, 10:33 PM   #2
T_Hulse
Tile Contractor
T_Hulse's Avatar
Hi Fred,
I also use the Ditra underlayment in a situation like this, especially when there are slab cracks. It goes right under the tile. Expansion joints go in the grout joint in place of the grout.
Tom Hulse
New here? Read this first!
Visit my web site here
Old 08-31-2007, 07:45 AM   #3
FredF
Radiant Flooring Order of Installation Materials
So, is this a complete strategy:
(From bottom up)
Slab
ThermoTile heating element (mats hot glued to floor)
Self-leveling mortar
Unmodified thin-set
Ditra product
Unmodified thin-set
Tile and Grout
** Items listed below the "---" must be separated with appropriate expansion joints because my tile area is 39x25. (Is this correct? Or, does the expansion joint need to go all the way through the ditra product and/or the heating element?
Old 08-31-2007, 08:57 AM   #4
Welcome, Fred.
I don't know how your heating system manufacturer wants you to deal with movement accommodation (expansion joinst, etc) for their products, and I think you should discuss it with them for a room that size.
Since you report no expansion joints in your slab, I presume that means no "control" joints, either?
You should review Schluter's requirements for "movement joints" in their literature. They are pretty specific on how they want each type treated, including dimentional guidelines for installations over heated floors.
If you are not honoring any expansion joints in the substrate, you'll generally not need to break the Ditra surface, but you can. Schluter has a product for treating such joints if you intend to waterproof the Ditra surface.
My opinon; worth price charged.
The Tile and Stone Magazine for Consumers!
MAKITA TOOLS They're blue to match my eyes. Y'ALL NEW VISITORS READ THIS HERE! ...... HUNT ELK & IBEX IN NEW MEXICO
Old 09-03-2007, 06:53 PM   #5
FredF
R-value of Area Rugs
I'm planning to install radiant flooring under a large field of tile in a basement (900 sq. ft.) The vendor of the radiant floor is thermotile, and they recommend (require) installation under a floor with an r-value no higher than 1.0. I plan to install ceramic (r-value est: .15), and would like to put large area rugs on the floor. Has anyone installed an electric radiant heat product and put area rugs on top of it? Are there ways to determine the R-value of a rug? I'll take any advice on the subject.
(Yes, I've already e-mailed thermotile and am awaiting a response).
Old 09-03-2007, 07:02 PM   #6
e3
Noble Company Guy
e3's Avatar
never heard of thermo tile....but i would think a rug would be higher then 1.
Eric
http://www.noblecompany.com Nobleseal ,Chloraloy
waterproofing ,crack iso,sound iso,showers
Old 09-03-2007, 07:17 PM   #7
flatfloor
"da Leveler"
flatfloor's Avatar
I tend to agree with Eric. The material the rug is made of will tell you more than anything.
Jim Buckley
Tile Calculator
New Here? Read this!
Old 09-03-2007, 07:25 PM   #8
dnlblank2
It depends so much on the rug.
John Siegenthaler lists the following in the Appendix to Modern Hydronic Heating.
1/4 inch nylon level loop R=1.36
1/2 inch polyester plush R=1.92
Foam padding 8 lb. density R=4.4 per inch
The padding really gets you on the R value.
If you don't have Siegenthaler's book you might want to give it a read. You might find it at the library of a trade or technical school.
David
dnlblank2 is offline   Reply With Quote
Old 09-03-2007, 07:30 PM   #9
I dunno, I've heard of carpet with R values as high as 2. Without the pad.
Could be rugs that high, too, I would guess.
You trying to heat the room with this radiant floor, Fred, or just warm your tootsies? Seems like if it's just to keep from walking on cold tile, you could save a lot of dinero by eliminating the heating system and using the rugs, eh?
Young David's quick, eh?
Old 09-05-2007, 10:51 AM   #10
FredF
Follow-up Information on Radiant Flooring and Rugs
I'm posting this just in case someone is later reading this thread after searching for radiant flooring, area rugs, r-value, thermotile, warmlyyours, etc.
The sales folks at ThermoTile wrote me back about the area rug issue. While the installation demands flooring with an r-value of 1.0 or less, the thermotile product passed UL testing with an r-value of 11. The manufacturer recommends not approaching this limit with anything sitting on the floor; but taking a margin of safety of 50%, that would give you r 5.5. I've found some indexes of common r-values. Looks like absent other information, wood has an r-value of 1 for every inch of thickness. Carpets are generally rated by multiplying 2.6 times the thickness of the carpet.
CX, I am using the radiant heat as the secondary source for heating in this space; but have experienced tile in a basement in a baltimore winter-even with a decent amount of forced air circulating in the room. My experience is that the tile is frigid...
Old 09-05-2007, 10:52 AM   #11
FredF
The book
David,
Thanks for the info on the book; I'm going to check it out online. If you're interested, my previous follow-up post had some information.
Old 09-05-2007, 10:57 AM   #12
FredF
Expansion Joints, Etc.
CX,
Thanks for the info. Schluter recommends expansion joints every 12' to 16' in all directions on top of Ditra. ThermoTile suggests using a latex-modified grout for the entire application; haven't verified this with Schluter yet, but I plan to discuss with them.
Old 09-05-2007, 01:01 PM   #13
JTG
Tile Contractor
JTG's Avatar
Fred.
If you use the Ditra try and get Ditra Set mortar. When you use tile that are that large with Ditra you will want to use this mortar or a non latex modified mortar or it will take forever for the mortar to dry.
Remember that 18x18 tile are not easy to set if the substrate has ANY bumps, waves etc. so you want FLAT
For getting self leveler on the area as large as you have I would look to have a company that does this type of thing come in and do the pour or you are going to be fighting a mix and pour battle that if you start to fall behind is going to lead to an uneaven floor. You will need lots of help to keep everything moving from start to finish.
Compare the cost of doing the self level with using a mat heating system such as Nuheat. A system that you wouldn't need to pour a self levelor over.
Good Luck
JTG
Jerry The Tile Guy
Seattle, Washington
"All women should know. Men are just like floor tile. Layed well the first time they will stay in place forever."
http://jerrythetileguy.com
Ask for Ryan
Old 09-05-2007, 01:16 PM   #14
FredF
Jerry,
Thanks much for the advice. We have been considering the challenges of pouring that much SLC. I'll take a look at getting a contractor as another option.
Old 09-07-2007, 09:11 AM   #15
FredF
Self-leveling Concrete
All,
I'm going to be pouring SLC over an electric radiant flooring installation. I'm a DIYer - this will be my first attempt at radiant flooriing, and my first experience with SLC - needless to say, I'm a bit nervous.
The Home Depot by my house carries a product called LevelQuik for about $29.00/50lb. bag. I'm doing a large area, and will need to buy many bags, so price/unit is a concern.
What's the best brand of SLC for price/quality? Any better places to shop other than HD to get the stuff? I also have a Lowes/84 lumber nearby and haven't checked either yet; but suspected it would be close to Depot's price.
Why is SLC so expensive?
Fred
Buy John's New Book!   Tile Your World Online Store   Contractors Direct Tile Tool Store   Wedi Shower System Solutions
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
