Old 08-23-2007, 09:04 AM   #1
c31grif
Questions RE: concrete grid layout
Hello all, I've been looking around for a couple of weeks and now I have a question: I work alone and am wondering if there is any trick that you all use to hold one end of your chalk line when trying to mark a concrete slab. I know it must be simple, but I don't know how to do it. Please advise.
...Caleb.
c31grif is offline   Reply With Quote
Old 08-23-2007, 09:11 AM   #2
Brian in San Diego
Brian in San Diego's Avatar
Caleb,
I feel ya...I work alone as well. Tie something like a big nut on the end. Set a block on the string. When you pull the other end, the nut will keep the string in place.
Old 08-23-2007, 08:51 PM   #3
c31grif
Thanks Brian, good tip. I should have thought of that myself.
...Caleb - Service 1st
Old 08-23-2007, 09:26 PM   #4
Jaz
Michigan Tile Pro
Jaz's Avatar
How have you been doing it so far? It must be working fairly good otherwise you would have come up with the answer already.
OK, OK I know... Make your two marks, then lay the slightly exposed line on one mark and place the edge of your 5 gal clean-up water bucket to hold the line. Adjustments are simple, then walk to the other mark on the floor and you know the rest.
Jaz
Troy, Michigan
Custom TileSetter (retired) - Method & Product suitability consulting
DIRECT Containers MARBLE from ITALY - GREECE; PERLATO di SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - ARETI WHITE - CALACATTA - others - Slabs - Tiles - Custom marmo.sicilia@yahoo.com
Old 08-23-2007, 09:48 PM   #5
chuck stevenson
...Caleb
I wrap the line around a brick, or block or two.
Chuck
No curb, walk-in shower.
Old 08-25-2007, 09:25 PM   #6
c31grif
Thanks for the input. Jaz, I've been using a straight edge up until now (only works well in small rooms). Plus, I seem to have been running into more concrete slab in the past few months (going more into new construction than remodel). Sometimes I've had a helper, but now I work alone (quality control). Thanks again for the input. I was thinking about trying one of those laser squares, but I have concerns about the accuracy.
