Old 08-07-2007, 11:38 AM   #1
musher
Ledger board for starting wall tile
So, I was looking at a pile of boards trying to pick out one with no crown or bend to use as a ledger board to start my tiling on a tub surround.
Seems like five feet of dead straight wood isn't too common anymore.
Then it occurred to me that there might be a use for greenboard in a tub surround after all.
Sliced out a chunk of factory edge with my pocketknife. Put a little blue tape on the edges to keep down the crumbling and to keep the thinset from bonding to the paper. Screwed it up with a couple drywall screws in each stud and went to town.
Let things set up for a few hours and took it off. Worked great.
rob.
musher is offline   Reply With Quote
Old 08-07-2007, 11:44 AM   #2
onereelbigfishy
Are you taping your joints as you go? Is that a fan in the shower wall? I've never seen that before...
-Marlin
onereelbigfishy is offline   Reply With Quote
Old 08-07-2007, 11:46 AM   #3
musher
Taping as I go yep-you can see my handy roll of tape there on the tub so I don't forget a joint.
Seems like it goes about 50/50 around here with the fan in the wall or ceiling.
That's the way this one was originally built.
rob.
Old 08-07-2007, 11:52 AM   #4
milner351
it may be old school, but I still like the look of good old 4x4 white tiles in a bath!
drywall is a GREAT idea for a ledger.
I seem to always have plywood scrap around so that's what I've used the last few times, seems most important to mix tiles from different boxes when doing shower walls if there is any size variation - shows up more on a wall where gravity is applying pressure to the spacers (last shower I did was 12"x12" with 1/8" spacers) as apposed to a floor where you don't have to worry about everything sliding down after you get it set!
interesting fan placement indeed!
Is that Fan in an outside wall?
John aka Milner
Mechanic turned Mechanical Engineer -
hopeless multiple DIY project starter.
milner351 is offline   Reply With Quote
Old 08-07-2007, 12:05 PM   #5
TedL
Unless that's a really short tub, those are 6x6 tiles.
TedL is offline   Reply With Quote
Old 08-07-2007, 12:05 PM   #6
musher
Yes the fan is in an outside wall. The exhaust is routed down a foot or so before it runs outside. This provides an airlock to prevent warm air from charging out of the vent during the winter. You get a slug of warmer air trapped in the top of the pipe, and that nice -50 outside air can't rise up to spill in.
That may be why the contractor who built the house put it in the wall rather than the ceiling. There's not enough room in the truss above there to create a cold air trap in a horizontal exhaust run.
6x6 is right.
rob.
Old 08-07-2007, 12:08 PM   #7
ChrisIL
ChrisIL's Avatar
Perhaps those are 4" tiles. This place sounds like an igloo.
Chris
Outside of a dog, a book is man's best friend; Inside of a dog, it's too dark to read.
- Groucho Marx
ChrisIL is offline   Reply With Quote
Old 08-07-2007, 12:12 PM   #8
musher
North Pole, Alaska. We usually have 2-4 weeks of -50F or colder every winter.
Can't tell you how cold it really gets, since my thermometer only goes to -60.
rob.
Old 08-07-2007, 12:35 PM   #9
river-wear
river-wear's Avatar
Nice to know you get water in liquid form up there!
Michele (DIYer on hiatus from projects... for now)
"Happiness... it lies in the joy of achievement, in the thrill of creative effort." - FDR
river-wear is offline   Reply With Quote
Old 08-07-2007, 12:37 PM   #10
onereelbigfishy
You should be building a sauna not a shower!
-Marlin
Old 09-27-2016, 09:13 PM   #11
DAVE-DOR
I was looking around for something to use as ledgers and found a bunch of scrap drywall, so I think I will try this (10" x 14" ceramic wall tile). I don't really want to use clear pine 1 x 3 or trim a factory edge off a part sheet of plywood. Thanks for the confirmation this should work.
DAVE-DOR is offline   Reply With Quote
Old 09-27-2016, 10:01 PM   #12
tatumjonj
You know what else works great since this ten year old thread has been revived? MDF casing. It's super cheap and typically dead flat and straight. Throw some tape on the edge to keep it from swelling or sticking and throw it in the trash and cut a new piece every time you need one. A 17' stick of plain casing is like $6.
Jon
