Old 01-18-2007, 12:49 PM   #1
flames9
Took down backsplash tiles, brown paper of drywall showing
Good day. Wife and I took down 4X4 backsplash tiles in our kitchen. No major damage to the drywall, ie holes, but one can see the brown paper. And of course its a bit uneven in some areas. had 1 guy that does tile come by and said it was not a problem, he could just tile over the brown paper, simple as that. He installs tile for a living. Had another fellow come by who is a general contractor and advised against of just tiling over it. He advised putting in all new drywall. Who is correct? With just the brown paper, does that provide enough holding power? As well we will be installing granite counter tops, new dishwasher and above range microwave, and no were not made of $$, just trying to upgrade a few things and make our condo unit different from others in our complex in prep to sel lin 2-3 yrs time. Many thanks for the help.
flames9 is offline   Reply With Quote
Old 01-18-2007, 04:50 PM   #2
EEEO
General (Tile) Contractor
Most likely it would be fine, but if it were me, I'd cut it out and replace it. I don't like to do things twice.
=Eric=
General contractor with a tile habit.
EEEO is offline   Reply With Quote
Old 01-18-2007, 04:55 PM   #3
Rd Tile
Tile Man
Rd Tile's Avatar
After you remove the countertop, I would replace that drywall and start fresh, install the granite top and then the new tile.
Not a big deal.
Old 01-18-2007, 05:00 PM   #4
Maack
Maack's Avatar
hi Flames
removing those tiles ripped off the drywall surface paper, leaving the *backing*paper only
not good for much of anything now incl. tile
please replace the sheetrock and save yourself from a faulty tile install
Maack
Pro remodeler
N. Virginia
Maack is offline   Reply With Quote
Old 01-18-2007, 05:29 PM   #5
JTG
JTG's Avatar
Gosh boy's it is only a backsplash! I would paint the brown paper with a couple coats of latex primer and then put tile over it. You will be fine.
Good Luck
JTG
Santa Seattle
Ballard
Old 01-18-2007, 05:30 PM   #6
I disagree with all my colleagues here. I tile over stuff like that all the time in the kitchen. Use thin set. It will fix the holes as you go.
Welcome aboard.
Old 01-18-2007, 05:32 PM   #7
Rd Tile
Tile Man
Rd Tile's Avatar
Use some thinset and leave it, you'll be fine.
Old 01-18-2007, 05:33 PM   #8
flames9
I guess everyone differs!! As stated earlier, 1 guy that does tile said it was no prob, a general contractor stated i was crazy to tile over it. Then talked to another fine fellow that specializes in tile, but lives too far away said tiling over the brown paper should be fine!! Decisions decisions!! First guy said he would gaurentee his work for up to 5 yrs, and we plan to be well gone by then. Again, many thanks for taking time to reply, I appreciate it.
Old 01-18-2007, 05:49 PM   #9
MudMaker
Karl Marxist-Gettin ready for the Revolution
MudMaker's Avatar
Flames,
What you need to tile is a flat surface with no rippling or lows and highs. The texture of the surface is not as important as it's flatness. If you fill in those divits and can get a flat surface you should be good to go.. Check and see how straight and flat the surface is.. You need to determine whether it's flat enough to tile.. The flatter it is the better the install will look...
You ask someone how to build a tree house - yer gonna get different answers but the results will be the same...
There are no incorrect answers above, just preferences...
mm (aka "Paco")
Old 01-18-2007, 06:42 PM   #10
Another vote to just tile over. Make sure you don't have any loose paper. Drywall has a way of delaminating a bit. Get rid of the shreads of paper that aren't flat and tight to the wall.
New to the forum? Read this. - - - Click here to add your name to your own signature line
Old 01-18-2007, 06:52 PM   #11
I'd tile over it, done it many times.
Old 01-18-2007, 06:56 PM   #12
flames9
Many thanks all, really appreciate it.
Old 01-18-2007, 07:01 PM   #13
SteveVB
Remodeler -- D.C. Area
I'd seal it with Kilz or some other non water based fast dry primer and set tiles over it. The sealer will keep the paper from delaminating further with the moisture from thinset or mastic. As long as there are no breaks in the board you should be fine- I do this all the time for kitchen jobs. Blowout patches for any holes and or breaks of the core and then tile away.
Have Fun
Steve
SteveVB is offline   Reply With Quote
Old 01-18-2007, 07:10 PM   #14
flames9
Yes I was wondering if I should seal it with kilz. Thanks
Old 01-18-2007, 11:21 PM   #15
sandbagger
sandbagger's Avatar
a better sealer is Gardz. made specifically for sealing the paper damaged like this and prevent further bubbling and delamination. But that's really more commonly used to prep for mud and paint. I'm really more with the crowd that says just thinset and be done.
-art-
__________________________
Patrick Henry
