Old 12-26-2006, 09:17 AM   #1
LB57
Height of toilet flange.
How much should the toilet flange extend above the finished floor? Or should it be level with the finished floor?
LB57 is offline   Reply With Quote
Old 12-26-2006, 09:48 AM   #2
Dave Taylor
Dave Taylor's Avatar
Howdy LB57
LB57 is sooooo hard to pronounce.... give us a first name we kin use.
Ol' Mike2 outdid his-own-self on this terlit' flange primer.
Check it out at:
http://www.johnbridge.com/vbulletin/...ghlight=toilet
Mind Ifn' I calls' you 57 :---)
Dave T (DIY'er)
the net.
Old 12-26-2006, 12:21 PM   #3
Welcome, "Ell-Bee".
See Dave, ain't nothin' hard about pronouncing that, eh?
Old 12-26-2006, 12:30 PM   #4
prashster
prashster's Avatar
The flange should sit flush on the finished floor.
Chronic DIYer
prashster is offline   Reply With Quote
Old 12-26-2006, 12:57 PM   #5
Michaelc
Hi LB57
plumbing codes say toilet flanges should not be below the finished floor, or flush. the ideal is to have the flange set on top of the tile floor. but you wouldent have any problems if you tiled to a toiet flange that can not be reset, just replace the wax seal with the one that has the extension on it.
Michaelc is offline   Reply With Quote
Old 12-26-2006, 01:05 PM   #6
ddmoit
ddmoit's Avatar
"...but you wouldent have any problems if you tiled to a toiet flange that can not be reset..."
I just did that without any problems. The flange is flush on a concrete floor. I tiled up to the edge with fairly thin glass mosaic tile. The top of the flange is still well above the tile. I installed a new Toto toilet with a regular size wax ring. It was the easiest toilet I ever set.
Dan - a DIYer in SE Tennessee
Old 12-26-2006, 01:18 PM   #7
Michaelc
works for me
Old 12-26-2006, 02:23 PM   #8
MudMaker
MudMaker's Avatar
El-Bee,
Howdy,
If you go to the top of this page - upper left, you'll see UserCp.. Click on that, and under edit signature put what you want us to call ya... We're pretty friendly here and on a first name basis.
Also, you can post all of your questions on the same thread.. It keeps the continuity your project intact...
mm (aka "Paco")
