Old 11-06-2006, 09:39 AM   #1
JeanneS
Need help to remove stains from marble
I have an antique wooden (cherry?) washstand which has a marble slab top, 16"w X 30"h and approximately 1" deep.
The marble is stained along the right side with what may be wood stain which was used on the washstand at some time and allowed to seep into the slab.
There is also a much lighter, larger stain that spreads across most of the left side top of the slab, which I'm guessing may be from water that stood on the slab for a lengthy period.
Do you have any suggestions on how I might attempt to clean either stain?
I am sending two photos of the slab.
JeanneS is offline   Reply With Quote
Old 11-06-2006, 12:01 PM   #2
Stonehenge
Mineral Polishing Education Specialist
Stonehenge's Avatar
Hi Jeanne,
Unfortunately wood stain that has penetrated a bianco cararra is virtually impossible to remove. If possible switch this stone out, contact your local granite and marble fabricator and you will easily be able to get this exact stone.
Good luck,
Michael of Stonehenge
Stonehenge is offline   Reply With Quote
Old 11-06-2006, 05:04 PM   #3
Davestone
Florida Tile & Stone Man
DITTO
http://Davestonestile.com
Old 11-07-2006, 08:25 AM   #4
joh
Send a message via Yahoo to joh
before you give up on the stone. Take a razor and scratch the darkest area of that stain. If you see the color return, you can have that area grind and repolish. Do Not Give Up on that stone.
To provide quality natural stone care, restoration and maintenance through a network of qualified natural stone professionals.
Please do not PM me for support. Please request help on the forums.
joh is offline   Reply With Quote
Old 11-08-2006, 04:15 PM   #5
Davestone
I'd bet a million bucks that stain is all the way through that stone.
