Old 11-21-2002, 11:02 AM   #1
GFT
Hi all:
I'm curious to know any comments from the pros about heated floor (under tile) installations. What seems to work best (electric or water tubes) and have you folks run into difficulties or problems.
The way I'm seeing it done here (western NC)is to put the plastic line (water) down and then mud over. The installs I've seen are engineered floor trusses with 23/32" Vantech subfloor. Trusses are 16" OC. It's a very stiff floor system and the Vantech is T&G. The guys are putting the tubing directly over the subfloor and then mudding.
Any ideas/comments are appreciated. I'm planning on building my custom home sometime early next year and want to incorporate heated floors in the kitchen and baths.
Grant
Brevard, NC
GFT
GFT is offline   Reply With Quote
Old 11-21-2002, 11:11 AM   #2
flatfloor
"da Leveler"
flatfloor's Avatar
They both work well, is electric inexpensive where you live? That can be a major consideration.
Jim Buckley
Tile Calculator
New Here? Read this!
Old 11-21-2002, 03:19 PM   #3
Cami A
Official Hostess and Moderator at Large
Cami A's Avatar
Ok, Grant, I'll ask- why just the kitchen and bath? Heated floors are great throughout the house.
What you've seen done is fairly close to what we did in our house. I wanted the AdvanTech subflooring, but it's not available in the boonies. We settled for plywood, and applied some Thompson's. Lots of clips to hold the tubing in place, then we covered with concrete.
-Lovely Mackinaw City home for sale
Cami A is offline   Reply With Quote
Old 11-21-2002, 03:58 PM   #4
GFT
Talking
Hi Cami:
So is your radiant system elec or water? or other?
Yes, the Advantech is good stuff.
I'm guessing you have radiant floors throughout? Do you even have that in carpeted areas, if you have any? Is your flooring a built-up (i.e. trusses) system and did you float the entire surface or just your areas you installed with heat?
I've kind of just leaned at kitchen/halls/master only as a way to reduce cost but have a nice amenity. More stuff...more cost
Grant
GFT
Old 11-21-2002, 05:23 PM   #5
Hi Grant,
There are a number of threads here having to do with radiant heat. Try the search at the top right of the page.
Old 11-21-2002, 06:45 PM   #6
Cami A
Cami A's Avatar
Grant, we have RFH throughout the lower level of the house- it's still in the unfinished state, though. Carpet can be used with RFH- you just need to design that into your plan (loops closer together).
I'm not sure how you would save by putting in hydronic only in certain areas- you would still need a water heater or boiler, manifolds, expansion valves, etc, no matter if your system was throughout only part of the house. I can see the "tile warmers"- the electric mats being cheaper then. Those aren't really a heating system, but rather a "comfort" item.
Of course, up here I don't need AC, so I don't have to worry about running ducts. Something to consider if you do go with a complete hydronic system is the newer "mini-duct" high velocity air conditioners. Those look spiffy, but our handful of days over 90 just isn't enough to justify the expense of any ac system.
You can DIY this sort of system if you have the time and inclination. I have to say that the heat from the RF is exceptionally comfortable- no drafts, no registers to worry about.
Old 11-22-2002, 01:26 PM   #7
kdzgon
Official CPA -- JB Forums
kdzgon's Avatar
Spoken like a true northerner that neglected to look at a map...
kdzgon is offline   Reply With Quote
Old 11-22-2002, 01:50 PM   #8
Cami A
Cami A's Avatar
Laurie, I just figured those south of me have thin blood, and need the heat, too.
Old 11-22-2002, 02:00 PM   #9
GFT
Thanks for the reminder, John, about the search engine available here. It's a wonderful resource and I've explored it.
Cami, I'm going to do a lot more research on the radiant heating products out there. However, the PEX systems (for water) seem to be predominant in my area.
Thanks for all the comments, folks.
Grant
Brevard, NC
GFT
Old 11-22-2002, 04:27 PM   #10
flatfloor
"da Leveler"
flatfloor's Avatar
I'll bet it can get kind of nippy in West North Carolina. Who's side were they on in the Civil War?
Jim Buckley
Tile Calculator
