Old 09-18-2006, 11:37 AM   #1
o2manyfish
Need Help -Marble Tile on Wall Install
Hello, I Need a Little Experienced advice.
This is a tile installation in a bathroom. There are 4 disconnected walls. I am using a 12" Glass Rope Tile as a chair rail.
The lower 1/2 of the wall is marble tile (4x8) mounted on a 45 degree angle, on an offset pattern, with glass tiles inset every 3 cycles of the pattern.
However, I need to start tiling at the chair rail, down to the uneven stone floor.
The walls are backerboard. I tried the Marble/Granite thinset. But while it holds the tiles to the wall. The Marble tiles still slide down.
I am doing 1/16" grout joints.
How do I get the tiles to stay in place ? Short of having to tape each tile?
Thanks for your experienced advice.
Dave B
o2manyfish is offline   Reply With Quote
Old 09-18-2006, 12:56 PM   #2
cdahl
cdahl's Avatar
Ardex X7G Plus, a modified thinset mortar, will hold any tile on the wall. Mix the product at a 2:1 ratio, powder to water. At that consistency I can hang concrete blocks on the wall.
Craig
Craig
craigjdahl@hotmail.com
cdahl is offline   Reply With Quote
Old 09-18-2006, 01:11 PM   #3
T_Hulse
Tile Contractor
T_Hulse's Avatar
Any mortar that says it's non-sag will work. Pro-lite like is advertised on the right of this page will work. My favorite is Tec 3N1.
I would start at the bottom though. I lay out the wall with straight lines where I want the tile to go & stick with it. Tho bottom tiles still get the same same angled cuts, I just do those first & work up.
Tom Hulse
Visit my web site here
Old 09-18-2006, 08:15 PM   #4
Giovanni Lagana
You might want to try using finish nails in the grout joints if you need a little extra holding power.
Giovanni Lagana is offline   Reply With Quote
Old 09-18-2006, 11:07 PM   #5
oogabooga
I second Giovanni's advice on the finishing nails.
Rob.
oogabooga is offline   Reply With Quote
Old 09-19-2006, 01:30 PM   #6
bctile601
Tile Contractor
bctile601's Avatar
a finish nail in the joints may be a big mistake, first you would blow your joint size, and secondly, you will more than likely chip the edges of the marble on removal. The only way i would try that is to leave out the bottom cuts while the top dried resting on the nails. i never like to leave cuts out when working with natural stone of any kind. Seems to me the 3N1 is the best non-sagger i have used, but then again i have only used that and mapei's ultralight.
Brian---
No one cares how much you know until they know how much you care
bctile.com
bctile601 is offline   Reply With Quote
Old 09-19-2006, 02:45 PM   #7
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Why??
Do Brick layers start at the chair rail??
There is a differance between YOU NEED TO.......and YOU WANT TO
Billions of s/f of tile was set before the invention of Non Sag Thinsets and they did not start at the Chair rails
Now........if you WANT to...thats another story.............but you do not NEED to
Old 09-19-2006, 03:37 PM   #8
Giovanni Lagana
The nails I use are very small and work out to about same as a marble shim (1/16" ) as far as joint size goes . Now depending whether or not the stone has a beveled edge or not, the grout joint may show slightly larger on top. In my opinion I feel is a bad idea to install the stone with anything less than 1/16 " joint for a couple of reasons.
1. You need a little wiggle room for tile size variations and adjustments .
2. The grout will anchor will be much better that just between a bevel if it has one.
3. and last but not least.. When refinishing a beveled edge marble floor that has been installed with a butt joint, it looks terrible. The tiles can appear slammed together in some areas with a thinset line showing up where the grout line is supposed to be.
I also feel that Mixing thinset stiff to the point where its not going to require any shims or nails is asking for trouble .
