Old 08-23-2006, 05:37 PM   #1
tbal
tbal's Avatar
Help:ditra
1st post! 800 sq. ft. of slate in the entry way, dining room, kitchen, hallway and bath/laundry. Old linoleum gone, carpet gone, and front hall ceramic out the door Went with Ditra(bought it 1st, then read your reviews) Thanks for backing up my gut feeling. I adhere to the good foundation method of construction. START IT RIGHT! Please give me some tips on using Ditra!
tbal is offline   Reply With Quote
Old 08-23-2006, 06:22 PM   #2
tbal
tbal's Avatar
slate and ditra
Wow! You guys are tough! I know my question was a no brainer, I've never worked with Ditra before. Durarock yes, Ditra no, please, offer me some user tips on Ditra Thanks, Tim
Old 08-23-2006, 06:36 PM   #3
You should be able to do that. Most of the people on here are working folks...sometimes it takes bit of time for an answer. What is the floor made of? Ditra will overcome some deficiencies, but when you are spending that much, the prep is critical; you want to make sure the floor is ready for stone tile. Is the floor a slab or wood? Did you check out the deflection calculator in the blue bar at the top?
Old 08-23-2006, 06:46 PM   #4
lou432
Tile Man -- Southern New Hampsire
lou432's Avatar
Welcome TBALI, Gota first name we can call ya?
Go to the link below for Ditra installation+tec info if you hav`nt already ,I`m sure any other questions can be answered here.
http://www.schluter.com/english/prod...601-index.html
Louis
White sand+ blue water .
Find the grace in things that you can`t change, and help some body if you can!
"Van Zant"
I`d rather be on my Harley thinking about God than in Church thinking about my Harley .
My Tile Work Pictures
lou432 is offline   Reply With Quote
Old 08-23-2006, 06:57 PM   #5
tbal
tbal's Avatar
Thanks Jim. Mfg. I beam joist 16 in. O.C. , 3/4 in. tongue & groove OSB, and luann. I would have used cement board, but the ditra caught my eye. No moving kitchen cabinets,etc. And yes, no deflection test
Old 08-23-2006, 07:41 PM   #6
Rd Tile
Tile Man
Rd Tile's Avatar
You need 2 layers of wood flooring, 1/2" or better over the OSB, and did you say LUAN?, that shouldn't be anywhere in the mix, this is all assuming the I-Joists meet deflection specs for stone.
Old 08-23-2006, 08:19 PM   #7
tbal
tbal's Avatar
I was thinking of an old girlfriend, Luann, but yes I meant Luan! The luan has covered 2/3 of the old flooring. I'm retiling our 1st floor, and understand the need for floor integrity. Maybe ditra wasn't what I needed.
Old 08-23-2006, 08:48 PM   #8
Dan Clark
tbal, still need a first name.
I'm not a pro, but Ditra is my choice too. I think it is a fine uncoupling layer. But...
Ditra is just one of the components. It won't make up for deflection problems, warped floor, inappropriate underlayment, etc. I believe that Luan (not your old girlfriend) is one of the "bad" underlayments. Like particle board (my problem), I'm pretty sure that it has to come up or your project will have problems.
Have you used the "Deflectolator"? Take a look: http://www.johnbridge.com/vbulletin/deflecto.pl
Good luck,
Dan.
I am... Tileless in Seattle
Dan Clark is offline   Reply With Quote
Old 08-23-2006, 08:56 PM   #9
jdm
jdm's Avatar
Regardless of what you do, the luan has to go. It probably has voids and does not have enough structural integrity to be under a tile floor.
jeff
Go Rutgers!
Old 08-23-2006, 10:50 PM   #10
tbal
tbal's Avatar
I don't talk much, my typing skills....... joists; 16" OC Silent floor(10x2), 3/4 OSB T&G. Never a problem with my ceramic floor in the foyer, a small crack in the corner of the closet.
Lot's of linoleum taken out of the 1st floor. That's why there's alot of luan Staples,glue, just me Installing Ditra and slate(16x16).
Built up floor to match luan, scraped glue, patched seams and cracks jumped up and down Will someone give me an amen!!!
Old 08-23-2006, 11:06 PM   #11
tbal
tbal's Avatar
Hey Dan, my name is Tim, thanks.
Tim
_____________________
Everything starts with a good foundation.
Old 08-24-2006, 06:28 AM   #12
Tim, nobody's gonna give you an "amen" or "attaboy" until you fix your subfloor. As stated before, stone needs 2 layers of plywood, and the luan doesn't count. If you use Ditra, you need a layer of 3/8" (min.) plywood over the 3/4" OSB. If you switch to CBO, the layer has to be 1/2" or thicker. Second, someone's gotta look at them I-joists. It's not very likely they meet the L/720 deflection criteria, unless the house was designed for stone floors. Look for a manufacturer's stamp, then either call them or post it here,
Old 08-24-2006, 01:29 PM   #13
tbal
tbal's Avatar
Bob, We won't cut corners! I was trying to get it done without moving out all the kitchen cabinets. That will start as soon as we figure out the joists.
A good part of my project was covered with perimeter glued linoleum. We took all of it up and matched the rest of the floor with luan to even everything out.
Can we put the 3/8 plywood over the luan?
Our house was built in 1990. The mfg joists are Silent Floors. There are some other markings on the wood in red, but very hard to make out. The longest unsupported span is 14 ft.
Thank you everybody for your comments. Tim B.
Tim
Old 08-25-2006, 05:48 AM   #14
Tim, the 9-1/2" I-joists come in 3 flavors. The heaviest will work for stone but the lighter two won't. If you can't find something that says TJI-230, then measure the width of the flange and let me know.
The luan has to go. It's too soft to be in the subfloor, even under a layer of plywood. You can leave it under the kitchen cabinets.
Old 08-25-2006, 05:14 PM   #15
tbal
tbal's Avatar
Exclamation
It's just the thought of all the glue and staples The flanges on the joists are
1 3/4 W x 1 1/2 H. Would it be common to leave the kitchen cabinets in place and just build up around them? My biggest concern is appliances fitting, I think we could get used to the difference in the countertop heights. I would like to Thank you again for your time, considering all the other posts you keep up with.
Sincerely,
Tim Balstad
Tim
