Old 08-19-2006, 07:20 AM   #1
GregU
How do I blend Durock and sheetrock?
As I posted before, I had to take out tile and water damaged sheetrock from around the tub/shower in my bathroom. The previous owner didn't caulk around the fixtures when they tiled! I took it out and replaced with greenboard. Sounds like I made a mistake, everyone here feels I should take it out and replace with a cement type backerboard. When I took out the damaged sheetrock, I cut out 2-3" above the existing tile, then on the tub ends, I had to cut out over to a stud. Of course I won't be tiling up that far or all the way over to the studs. Anyway, what do I use to connect the two different materials together, and then what do I use as a topcoat on the Durock to smooth the surface for painting? Thanks. Greg
GregU is offline   Reply With Quote
Old 08-19-2006, 07:44 AM   #2
koihito
No one of consequence.
koihito's Avatar
Treat it just like dry wall. Skim, sand, prime, paint.
Nate
No one of consequence...
www.mikoskiconstruction.com
Old 08-20-2006, 11:42 AM   #3
GregU
Thanks. I would assume that I tape and mud the drywall/durock seams just like you would a sheetrock/sheetrock joint? Greg
Old 08-20-2006, 12:26 PM   #4
That's correct, Greg.
Old 08-26-2006, 08:13 AM   #5
JMingrone
Bob-
I have a similar sheetrock/durock situation. Gotcha on the seam between the 2, but are you saying you can also skim coat Durock with regular old joint compound to prep for painting?
Jay
JMingrone is offline   Reply With Quote
Old 08-26-2006, 09:15 AM   #6
Iggy
Yep! It will take whatever finish you top coat it with...just like drywall.
"The moment your past is more exciting than your future, you begin to die". - John Wooden, former UCLA Basketball Coach
Iggy is offline   Reply With Quote
