Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Tile & Stone Forums > Reference Liberry :-)
Closed Thread
Old 07-02-2006, 09:37 AM   #1
Mike2
Calculators for Deflecto, mud, and tile
Here is a link to a deck mud calculator DaveM put together. A real handy tool for estimating how much material you'll need for your shower floor.
Shower Floor Deck Mud Calculator
Deflecto: Wood framed floor joist deflection calculator
If you are building a Kerdi shower, see next post below.
Mike2 is offline
Old 08-06-2006, 08:24 AM   #2
Mike2
Deck Mud Calculation for Kerdi Shower Floors
The Mud Calculator can also be used for a Kerdi shower floor. However, since a Kerdi floor has one layer instead of two, a few minor tweeks to the calculation process is required.
Illustration - Shower size is 4' x 6' (48" x 72").
Referring to the example below:
  • Depth of the mud bed at the drain is installer determined, in this case 1 .
  • Depth at the far wall using the slope per foot of run rule will be 2.
We now have all the numbers necessary to complete the Input section of the Mud Calculator depicted below. Important note - you only need the Preslope input and output section of the Calculator. Totally ignore the Top layer deck mud thickness, leaving the default value of 1.5 as is.
Data input looks like this:
Solution - Deck Mud requirements for this Kerdi shower floor example is:
260 lbs. of Sand Topping Mix plus an additional 130 lbs of sand
-or-
65 lbs. of Portland cement plus 325 lbs. of sand.
Related Liberry articles
If this is your first Kerdi shower you might want to review the Kerdi Drain Rough-In article here. http://johnbridge.com/vbulletin/showthread.php?t=28637
And if you are unfamiliar with the term Deck Mud or how to make it, a review of these threads should be helpful. Deck Mud and Fat Mud and Deck Mud (Dry Pack Mortar) for Shower Floors
Furthermore, if this is your first go at building a shower, this Shower Construction Thread is a "must" read.
Mike2 is offline
Old 06-15-2007, 08:24 AM   #3
Mike2
Estimator for tile, thinset, & grout
Here is a handy tool compliments of Warmly Yours for estimating the amount of tile, thin-set, and grout for your project. Tile Estimator
Mike2 is offline
Closed Thread
HTML code is On
deflecto and marble tile handy_guy Tile Forum/Advice Board 2 05-11-2008 09:54 AM
Porcelain Tile and Deflecto Results John Bridge Tile Forum/Advice Board 22 07-22-2006 10:52 AM
To tile or not - Deflecto says L380 Tbakes Tile Forum/Advice Board 4 01-04-2006 07:05 AM
Tile and Deflecto questions cmoore Tile Forum/Advice Board 9 01-05-2005 07:59 PM
Floor Tile / Deflecto Question Brewbeer Tile Forum/Advice Board 16 06-03-2003 06:06 PM
