Old 04-30-2006, 06:34 PM   #1
steve weaver
fiberrock HELP!!!!
i am having a multible problem with this product. i contract for a retail store and they supply it and insist that i use it. i am using it on showers and somehow water is getting under the tile and making the board expand. causing the tile to lift and causing extensive water damage. i am caulking the shower and putting a pitch on the seat and curb.(that is where the damage usually occurs). WHAT DO I DO?
steve
steve weaver is offline   Reply With Quote
Old 04-30-2006, 07:09 PM   #2
dbol
dbol's Avatar
fiberock can not be used in showers. If you are using usg product you should use their aquatough it is a 1/2 inch board. if you are nailing through the board there is a good chance that the water is getting through there.
doug
dbol is offline   Reply With Quote
Old 04-30-2006, 08:03 PM   #3
steve weaver
is it possible that the fiberock aquatough is wicking moisture off of the liner and working its way up?
Old 04-30-2006, 08:15 PM   #4
steve weaver
fiberock failure
is anyone having a hard time with this product getting saturated and failing?
Old 04-30-2006, 08:20 PM   #5
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Never used it on walls. Hate it on floors. What's your installation?
Shaughnn
Old 04-30-2006, 08:22 PM   #6
muskymike
muskymike's Avatar
Hi Steve, I merged your two threads together. Sorry I can't help ya, I never used the stuff.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Old 04-30-2006, 09:43 PM   #7
Tileworks
Tile Contractor -- Akron, OH.
Tileworks's Avatar
I've seen a piece of fiberock supposedly floating in a jar of water for months on end and it looked invincible. Could of been a gimmick, though.
Nonetheless, I use fiberock almost exclusively as an underlayment for floors. I love it. I trust it. I seem to be alone in this arena though.
When it comes to shower walls however, I still rely on good ol' wonderboard.
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline   Reply With Quote
Old 05-01-2006, 05:28 AM   #8
Mountain Tile
Tile Contractor -- Northeastern PA.
Mountain Tile's Avatar
i have a builder who insists i use 1/4" fiber rock for floors i tried to talk him into using a 1/2" board but he likes the height transition. so what i do is tell him he is responsible for a underlayment failure. i dont think will have problems any way he really builds a good subfloor and i nail the heck out of it. but i honestly think i would refuse to do walls with it. you cant put a price on your reputation.
Mountain Tile is offline   Reply With Quote
Old 05-01-2006, 05:52 AM   #9
I'm not a backer board pro at all, but I know that 1/4 in. is fine for floors and countertops. Hardibacker even specs 1/4 for walls.
As to Fiberock, if you want to use a USG product, what's wrong with Durock? Or is Fiberock from GP? I've crumpled 1/4 in. Fiberock in my hands. Have to admit I've never used it.
Old 05-01-2006, 01:19 PM   #10
Art in Stone
Flooring Contractor -- Las Vegas
Steve, in your original post, it says "i am caulking the shower and putting a pitch on the seat and curb.(that is where the damage usually occurs). WHAT DO I DO?"
Are you using this on the seat and dam? Are you waterproofing the seat and how are you attaching this stuff to the dam?
Also "is it possible that the fiberock aquatough is wicking moisture off of the liner and working its way up?". Is this stuff on the liner or is it an inch or two off of the liner?
Ramon
"If you don't have the time to do something right, where are you going to find the time to fix it?
Stephen King
Art in Stone is offline   Reply With Quote
Old 05-01-2006, 01:42 PM   #11
JTG
JTG's Avatar
Steve
I think that I'm thinking like romon is. there is a construction or applications problem here. Do you fabricate the benches and curb? Are all of the seams taped. Do tell us more about the curb construction.
JTG
Jerry
Santa Seattle
Ballard
Old 05-03-2006, 08:06 PM   #12
steve weaver
hey guys,
thank you for your help. we have solved the problem. i had a meeting with the local rep. that sold us the material and he decided that he didn't tell us that fiberock absorbs water, stays saturated, and forgot to tell us that it needed some sort of waterproofing. being that it stays wet all the way through it then soaks the studs under it and then travels to destroy the floor outside the shower. he finally determined this after looking at the fourth failed shower. if i had known more about this product i wouldn't have used it for walk boards out in the mud. i would not recommend fiberock for a dog house.
steve
Old 05-03-2006, 08:30 PM   #13
Art in Stone
Fiberock tile backer is used on surrounds, and doesn't need a membrane over it unless it's something like a bench or niche. If it is, it needs it no matter what kind of board it is.
What Fiberock did you use?
Ramon
Stephen King
Old 05-03-2006, 08:37 PM   #14
RexModeling
RexModeling's Avatar
fiber rock is the grey stuff right, the one that is like sheet rock but it has like fiber glass , what about perma base , it is good for shower enclouseres??
RexModeling is offline   Reply With Quote
Old 05-03-2006, 08:39 PM   #15
steve weaver
i used 1/2" aqautough. never used the product before and won't use it again. i started contracting for a retail store recently and other subs had been using it before i got there. they didn't stick around long enough to warrant a problem. i have since given the store a choice. they either change to the kerdi system or they find a new contract setter.
