Old 04-08-2006, 07:51 PM   #1
New_2_forum
Cement Backer + Mortar
Hello
First, This is a great forum everyone. Thanks for all of the good advice.
Second, I am redoing my kitchen. I have put down 1/2 ply on top of my subfloor.
now I am bringing in a contractor to do the tile.
However I am worried. He said that it is not necessary to put thinset down when installing the cement backer board.
Is this right??? OR is it always necessary???
New_2_forum is offline   Reply With Quote
Old 04-08-2006, 07:58 PM   #2
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
Hi New,
Well, the best bet is to follow the manufacturers installation instructions. That said, I think most, if not all, of the backerboards out there require thinset (real thinset in a bag that you mix with water. No "premixed" thinset which is really mastic) to be used to set the CBU. Makle sure the recommended nailing/screwing pattern is followed too!
Old 04-08-2006, 07:59 PM   #3
It is necessary...read the manufacturer's instructions - they are quite explicit. The thinset fills in any minor imperfections on the floor and provides a fully supported decoupling layer. Not doing it voids any warranty from the manufacturer and risks failure. Also make sure he uses the specified alkaline resistant fiberglass reinforcing tape on the seams and leaves a 1/4" at the edges of the room.
Old 04-08-2006, 07:59 PM   #4
JTG
JTG's Avatar
Backer board on the floor need thin set no if's and's or butt's. That is the way it is. Go to the web site of the backer board he is going to use and read the directions. Wouldn't settle for anything less or you are asking for possible trouble.
JTG
Jerry
Santa Seattle
Ballard
Old 04-08-2006, 09:58 PM   #5
Charles P
Their all correct if he doesnt know that, I would get acouple other bids and go with someone else to do the work.Good luck.
Charles
Charles P is offline   Reply With Quote
Old 04-08-2006, 11:26 PM   #6
jdm
jdm's Avatar
See a concensus building?
If he won't use the thinset, don't use him. It's that important.
jeff
Go Rutgers!
Old 04-09-2006, 09:24 AM   #7
I replaced a bath floor about 2 years ago that didn't have thinset under the backerboard. I touched up the grout several times within 6 months but it kept coming out. No problems now.
