Old 04-05-2006, 09:04 PM   #1
brians
Best Grout Sealer at Lowes
What is the best grout sealer I can find at a Lowes?
If none are that good I will try to go somewhere else to purchase it.
What do you recommend?
brians is offline   Reply With Quote
Old 04-05-2006, 09:37 PM   #2
DonB
Do not use Aqua Mix UltraSeal. Even though it's free, it's not worth the price.
The Aqua Mix Color Enhancing Sealer is good, if you're looking for an enhancer.
Old 04-05-2006, 09:53 PM   #3
Mike2
Do you have a Home Depot nearby? If so look for either Aqua Mix Sealer's Choice or Miracle 511 H2O or 511 Porus Plus. I'd recommend against the TileLab products you will likely find at HD.
StoneTech Pro sealers available through the TYW Store here are good and priced very competitively. Many here seem to go with the StoneTech Pro BulletProof sealer however for grout alone with porcelain tile I was personally advised by StoneTechPro Tech Support to use their Grout Sealer product.
Old 04-06-2006, 07:37 AM   #4
mistersludge
YMMV, but the ATL HDs don't carry the Aquamix Sealer's Choice. I ended up buying at a local tile store. Shortly afterward, Floor&Decor started carrying it at half the price I paid.
Ted
mistersludge is offline   Reply With Quote
Old 04-06-2006, 08:11 AM   #5
DonB
Gulf Coast HD's don't carry any Aqua Mix products. Tile Lab only. I had to pay $35 a qt at Florida Tile for Sealer's Choice. Another place sells gallons for $88.
Don
Old 04-06-2006, 03:05 PM   #6
TJoeC
TJoeC's Avatar
Location: suburban Minneapolis, MN, home of the Golden Gophers
Yikes, I just paid $45 a quart because I was impatient! Where is it $88/gallon?!
By the way, there is a separate forum for sealers and such. I assume a moderator will move this over there soon, and you might get some traffic... or check my sealer survey thread I posted on this board temporarily. (The cat's away )
Joe - Now I'm worried!
www.kanecrumley.com
TJoeC is offline   Reply With Quote
Old 07-04-2006, 09:07 AM   #7
bmwpower
<<StoneTech Pro sealers available through the TYW Store here are good and priced very competitively. Many here seem to go with the StoneTech Pro BulletProof sealer however for grout alone with porcelain tile I was personally advised by StoneTechPro Tech Support to use their Grout Sealer product. >>
Mike2,
Which "Grout Sealer product" are you referring to? Impregnator Pro?
--Eric
bmwpower is offline   Reply With Quote
Old 07-04-2006, 09:25 AM   #8
Mike2
Eric, see picher below. It is actually called Grout Sealer. This is the product StoneTech's support folks advised me to use for grout with porcelain tile. It contains MicroBan for inhibiting mold growth as well.
I don't think the on-line store here carries it though.
