Old 03-29-2005, 08:04 AM   #1
cabom
Why oh why is my grouting shrinking??
I am pretty pleased with the job I did on the bathroom vanity top. But--what am I doing wrong to cause some separation of the grout from the tile edges. Only in a few places has this happened but I still have more tiling to do and would like to not see this again. I used non-sanded grout because of 1/16 grout on the larger field tiles. The only place I have noticed the sep. is on the mosaic area that has 1/8" grout. The mosaic runs between the larger tiles.
Carol
cabom is offline   Reply With Quote
Old 03-29-2005, 08:16 AM   #2
Arn
Oregon Tile Guy
Arn's Avatar
My guess is that the grout didnt shrink, but was washed out too much during clean wiping. I am leary of unsanded anywhere except tight joint stuff like granite or DAL 4X4. I would have used sanded on those 1/16" too.
P A H : you could mix more NS grout, moisten the sunken grout and try to add more. It may bite in it may not. you could trim out the sunken areas with a utility knife and re-grout them deeper.
mix non sanded by hand. It should be the consistancy of room temp. adams creamy peanut butter.
best of luck!
Aaron
~Mind over Mortar
Arn is offline   Reply With Quote
Old 03-29-2005, 10:16 AM   #3
rspainhower
rspainhower's Avatar
Also you said you have more tiling to do. If you have a 1/16 to 1/8 in joint sometimes you can mix the sanded and non-sanded grouts to make sure there is no shrinkage effect. This may change the color slightly but its works great.
A lover of tile and the art of tile setting,
Randy
rspainhower is offline   Reply With Quote
Old 03-29-2005, 10:59 AM   #4
Scooter
Remodeler -- Southern Cal.
Scooter's Avatar
Usually too much water is the cause of shrinking.
Either in mixing or in cleaning up.
Scooter
WC Fields, "Its a Gift" 1934
Old 03-29-2005, 11:08 AM   #5
cabom
Many Thanks
Thanks to everyone for your suggestions. I'll bet all were correct on my amateur techniques.
Carol
Old 03-29-2005, 10:06 PM   #6
stefan
stefan's Avatar
carol
when you grout again, use a mix of wall and floor grout and it want happen again
good luck
Stefan
http://globalceramicdesign.com
stefan is offline   Reply With Quote
