Old 02-18-2005, 08:43 PM   #1
tilenovice
Durock vs. Hardiboard
Is there any difference between the Durock or Hardiboard cement backer boards?
I was told to use the Durock type by a friend but I need 1/4" thick because 1/2" will be too high. Durock only comes in 1/2", correct?
Tim
tilenovice is offline   Reply With Quote
Old 02-18-2005, 08:44 PM   #2
darby
Comes in both sizes. Comes down to preference. I prefer Hardi.
darby is offline   Reply With Quote
Old 02-18-2005, 08:50 PM   #3
e3
what you doing with it?
Eric
Mapei USA
Old 02-18-2005, 09:05 PM   #4
tilenovice
Ceramic tile floor. I have a 3/4" subfloor, I am going to put 1/2" plywood on top with the cement board on top of that.
Old 02-18-2005, 09:17 PM   #5
wessieball
I'm probably more of a novice than anybody here but from what I've read, 1/4" Hardibacker is stronger (compressive and flex rates) than Durock in any thickness and it's also stronger than 1/2" Hardibacker believe it or not.
I called and talked to one of the reps at James Hardie and he confirmed this. I guess the 1/2" was the same density as the 1/4" but it was too heavy so they reforumulated it to be less dense but thicker. The thickness isn't for strength, it's so that it can butt up against 1/2" drywall.
Can't speak for Durock since I didn't do any research on it.
wessieball is offline   Reply With Quote
Old 02-18-2005, 09:41 PM   #6
victor hardy
Hey Wessie,
Durock comes in a 5/16" thickness, too. That is a hair over the 1/4" thickness of Hardibacker.
I think Durock is almost all concrete sandwiched between 2 sheets of mesh. Hardi has some kind of fiber mixed in it(I think they call it "post consumer material").
I have used both, but the last few times I have tiled I went with Durock.
I am sure either one would be fine.
Victor Hardy
The Hardy Company Investment Group, LLC
victor hardy is offline   Reply With Quote
Old 02-18-2005, 09:53 PM   #7
e3
Thumbs up
either or...
Eric
Mapei USA
