Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Tile & Stone Forums > Reference Liberry :-)
Closed Thread
Old 03-24-2002, 12:03 PM   #1
Bud Cline
Underlayments - Ditra, CBU
CEMENT BOARD TILE UNDERLAYMENT
Description:
Cement Board is a rigid substrate made of Portland cement, aggregate and glass mesh that provides an exceptionally hard, durable surface that is able to withstand prolonged exposure to moisture.
Applications:
Ideally suited as an underlayment or backing surface for tub and shower surrounds, countertops, flooring and a variety of other interior and exterior applications.
Features & Benefits:
Long wrapped tapered edges are formed smooth and shatter proof.
Highly moisture resistant, will not rot, disintegrate or swell when exposed to water.
Can be used in both interior and exterior applications.
Impact resistant with excellent overall flexural, compressive, and tensile strength characteristics.
Cut to size utilizing a utility knife and straight edge.
This copy appears at and is borrowed from the Permabase website.
PERMABASE mfg by: National Gypsum http://www.national-gypsum.com
OTHER NAMES IN CEMENT BOARD:
DUROCK mfg by: US Gypsum http://www.USG.com
UTILICRETE mfg by: Fin Pan Mfg. http://www.finpan.com
WONDERBOARD mfg by: Custom Building Products http://www.custombuildingproducts.com
GLASCRETE
Fiber Cement Boards
mfg by: James Hardi Co. http://www.hardibacker.com\
Fiberock
Glass Mat boards
Denshield
Gold Bond eXP (National Gypsum)
USG
Foam Tile Backer Boards
Schluter Kerdi
Wedi
Laticrete Hydroban
USG Durock
Johns Manville GoBoard
Last edited by Tiger Mountain Tile Inc; 11-28-2016 at 01:54 PM. Reason: add/update links
Bud Cline is offline
Old 03-24-2002, 01:16 PM   #2
Bud Cline
TILE UNDERLAYMENTS (Schluter Systems) "DITRA"
Schluter®-DITRA is a polyethylene membrane with corrugated ribs cut back in a dovetail configuration and a special anchoring webbing (scrim) laminated to its underside. Designed for ceramic tile and dimension stone installations, Schluter®-DITRA serves as an uncoupling layer for problematic substrates, a waterproofing layer, and a vapor pressure equalization layer to accommodate moisture occurring at the underside of the substrate.
For details regarding Schluter®-DITRA <../products/h6.1-ditra.htm> or any other Schluter®-Systems products, please write or call the company at 194 Pleasant Ridge Rd., Plattsburgh, NY 12901-5841, tel.: 1-800-472-4588, fax: 1-800-477-9783, or visit our web site: www.schluter.com. To contact the Tile Council of America, please call: 1-864-646-8453 or fax: 1-864-646-2821.
http://www.schluter.com
edit: There are many of these uncoupling products available now. Currently there are no standards for them so we encourage you to buy from manufacturer's that you trust. Here's a few listings that are on the market today.
Ditra
Stratamat
Redgard
Closed Thread
HTML code is On
Ditra vs CBU Redrobster78 Tile Forum/Advice Board 24 11-04-2011 10:58 AM
CBU over Ply, then Ditra - should CBU be thinsetted down. AJMac Tile Forum/Advice Board 6 03-22-2011 07:09 PM
Underlayments POBO6 Tile Forum/Advice Board 9 01-30-2010 10:47 AM
underlayments? im confused.. b_ross Tile Forum/Advice Board 1 11-05-2005 08:51 AM
underlayments for marble scott anthony Professionals' Hangout 4 07-22-2005 07:03 PM
