Old 10-22-2004, 07:45 AM   #1
Unregistered
Guest
Posts: n/a
Help!! Too Much Sealer
I Have Sealed My Marble Floor With 2 Coats Of Sealer
It Is Very Sticky All Over And There Are Blotches
Help
Old 10-22-2004, 07:51 AM   #2
KChurch1
Maintanence/Restoration Pro
What kind of sealer did you use? If it's an impregnator sealer... you must wipe/buff the excess off the surface before it dries. The remedy for this is normally apply more sealer and buff off (impregnators normally re emulsify themselves) If it's a topical coating, you probably put it on too thick and it may need more time to dry or need to be stripped off.
Karen Church
Church's Home Services, Riverside, CA
http://www.stoneandtilecare.com
KChurch1 is offline   Reply With Quote
Old 10-22-2004, 09:37 PM   #3
doitright
doitright's Avatar
Hi Unregistered
In addition to Karen's reply, I suggest you call the number on the product you used, ask for technical assistance, explain your problem, follow their advice, and report back to us.
While you're at it, please register, and give us a first name!
John Koessler
Old 10-23-2004, 06:26 AM   #4
claycarson
Commercial Cleaning and Maintenance
Hey Unreg!
Don't feel too bad - putting too much on, or maybe I should say letting it dry on the surface, is the most common mistake with these products. It's very easy to do, especially if you're thinking 'paint' or 'wax'.
It's fixable and you did not ruin the tile. But stripping it off is not heaps o' fun.
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Old 10-23-2004, 06:28 AM   #5
claycarson
Forgot one thing.
You said it's marble. In your stripping/cleaning efforts, don't use acidic based strippers, like 'grout haze removers', vinegar, etc. They eat away at the marble, which will dull it.
Clay
www.tileboston.com
