Old 09-11-2004, 01:30 PM   #1
caa
Kerdi drain user error
Erg, I just knew things were going too smoothly to date.
Last weekend the Kerdi drain was mortared into place, and this weekend I connected the ABS plumbing. Unfortunately, I put a bit too much stress during the connection, which caused the flange to tilt and pop about 0.3inches on one side.
To avoid puddling, will thinset/mortar fix this, or should I crawl back under the house, and re-plumb the drain...
-Chris
-Chris
caa is offline   Reply With Quote
Old 09-11-2004, 05:09 PM   #2
muskymike
muskymike's Avatar
Hi Chris, if your slope is ok you can probably level the drain its itself. The piece that goes in the floor drain.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Old 09-11-2004, 05:43 PM   #3
David Taylor
David Taylor's Avatar
They must have fed you lots of vegetables as a kid, Chris.
If you can, redo the plumbing connection so it puts less upward stress on the pipe. Use thinset to set the flange this time, but put something heavy on it (a box of tile works well) and go easssy on hooking it up again.
The drain flange has to be supported and squeezing thinset under there will do that, but the drain flange will still be way out of level. You don't have to be perfectly level, but if I'm reading the bubble on your level correctly, that's a little too much out.
Nice work on the mud pan. It looks good.
The best result of a quality installation is a good night's sleep.
www.tile-experts.com -- Get Schluter products, like DITRA and KERDI, plus live help!
David Taylor is offline   Reply With Quote
Old 09-11-2004, 06:28 PM   #4
caa
_grumble_ yeah, maybe a bit too much spinach and a bit too much hurry...
OK, I'll do the 50m crawlspace crawl, saw out a pipe section, and fernco to the rescue...
BTW, I'll be making an order for some Kerdi and Keba any day now...
-Chris
-Chris
Old 09-12-2004, 08:30 AM   #5
Hi Chris,
I'm glad you decided to take David's advice. Saves me having to yell at you.
You must have really put some stuff on that drain.
Old 09-25-2004, 07:42 AM   #6
caa
Was able to get the drain levelled with unmodified thinset. Kerdi went in fairly quickly, and the overnight water test was a success.
There is one air bubble of about 1" diameter on the wall. I'll neglect this unless someone recommends that I slice the bubble, thinset it out, and patch with Kerdi band. I figure the 12" tiles that I'm using will have enough grip with the remaining 143 sq inches remaining.
-Chris
-Chris
Old 09-25-2004, 06:15 PM   #7
Chris,
That is the brightest Kerdi I've ever seen. Looks good, though. I agree on the square inch thing. A hundred inches are enough on a wall.
Old 09-26-2004, 04:06 AM   #8
Steven Hauser
STT Owner
Steven Hauser's Avatar
orange is back.
Clean
Sealed
Safe
STT Sealers with Attitude!®
Old 03-14-2006, 03:36 PM   #9
caa
Wink longest duration between posts ever...
and another job (finally) finished with the help of this forum, and mat'ls from Kerdi, Rondec, and WilsonGlass. That'll be the last time my spouse asks me to fix the house
-Chris
Old 03-14-2006, 04:52 PM   #10
slb
Chris,
Looks great. FYI, after reading about what happened to you when you connected the drain, I decided to put a 60 lb sack of concrete mix on our Kerdi drain so that it wouldn't move while I connected the drain pipe from below. Worked out fine.
Steve
slb is offline   Reply With Quote
Old 03-14-2006, 09:03 PM   #11
JTG
JTG's Avatar
Chris
Your tile work looks real nice.
Word to wise Don't try and hook up the drain line after the Kerdi drain has been set.
JTG
Jerry
Santa Seattle
Ballard
Old 03-18-2006, 05:17 PM   #12
caa
Thanks to all you experts in this community that educated me with your posts and advised me throughout!
BTW, I used the Felker FTS-50 tile saw for this job, and with one additional diamond blade, it made it though these 18x18x0.375" granite tiles slowly, but finished the job. The Rondec on the edges and corners eliminated the need for bullnosing the wainscoting tiles, and looks quite nice.
-Chris
Old 03-18-2006, 05:34 PM   #13
Mike2
Chris, very nice job.
I'm going to seal a couple of your pictures and put them into a New Photo Album that was kicked off yesterday The New Photo Album .
