Old 08-16-2004, 05:29 PM   #1
smokin joe
drain cover
i'm ready to pour concrete over the recently added shower plumbing. I have not added a drain cover for this yet. the drain pipe extends about 6 inches above the slab. should i install a drain cover before i pour concrete or just leave the pipe? i have also got some pipe foam that goes around the pipe before concrete is poured. do i use this as well?
smokin joe is offline   Reply With Quote
Old 08-16-2004, 06:34 PM   #2
Davestone
Florida Tile & Stone Man
I'm assuming this is a new one,not recessed, and your pouring the grade slab and not the shower floor slope and there's no supply lines imbedded in it? I would put some ducttape over it and the foam is handy in case you have to plumb the pipe a little later, so you'll have a little play in it.
http://Davestonestile.com
Old 08-16-2004, 08:10 PM   #3
MHI
Kitchen & Bath Remodeler
Are you using a clamping type drain for a tile shower pan liner? You may want to glue the drain on the pipe (cut to proper height first) before pouring the cement floor. I think it would be very difficult to do it later with the cement up against the pipe. The drain housing has to go into the floor some.
Matt
MHI is offline   Reply With Quote
