Old 03-08-2018, 12:04 PM   #1
usedsoup
What shower waterproofing method to use?
After doing some searching around about the various ways to waterproof a shower I still can't decide on what method to use.
All the major manufactures seam to carry similar things i.e. foam boards, liquid applied and fabric.
My only shower I've done before was the tar paper behind backerboard with two part mortar bed design.
I'd like to do something different this time.
My plan for the showeris a 40"×40" mud bed pan with tile on two walls and frameless glass surround.
Cost, durability and ease of install are my deciding factors.
What do some of you like use?
Nate
Sent from my SPH-L710 using Tapatalk
Nate
usedsoup is offline   Reply With Quote
Old 03-08-2018, 12:42 PM   #2
Redgard is easily available at your local Home Depot. I use it on occasion. I currently use the Durock shower membrane. It's just like hanging wallpaper.
Old 03-08-2018, 01:16 PM   #3
usedsoup
Durock membrane was one I'm heavily leaning towards.
Do you like to put it over durock cement board?
Anyone know why USG says you can't put it over drywall? If its just like kerdi, why not?
Nate
Old 03-08-2018, 01:20 PM   #4
I've always used it over sheetrock. I think I remember reading their reason for using only cement board is in case of a water leak inside the wall.
There's nothing wrong with either one, in my opinion.
Old 03-08-2018, 08:52 PM   #5
jwmezzanotte
jwmezzanotte's Avatar
It’s easier to use sheet membrane on drywall than cement board. If you do use cement board and sheet membrane dampen it first so it doesn’t dry out your mortar.
Quick and easy IMO would be sheet membrane on the pan with banding around the inside corners (less worry about proper thickness with liquid in a critical area)
Liquid over cement board on the walls (red guard/hydroban etc)
Don’t forget to mesh tape your seams
Old 03-08-2018, 09:04 PM   #6
I've gotta agree with Kevin on the use of the Durock Shower Membrane over whatever backing you feel most comfortable with. I would not be at all hesitant to use it over drywall if I wanted.
The only time I used it over Durock walls, I found it quite easy to install and wouldn't hesitate to do that again.
And I gotta disagree with John on the use of a liquid-applied membrane on the walls instead of the sheet membrane. By the time you tape and mud the joints, wait for that to dry, apply your liquid membrane and wait for that to dry, I could easily have put the sheet membrane over the walls, joints and all, and be tiling.
Different strokes.
Old 03-08-2018, 09:49 PM   #7
jwmezzanotte
I agree with you CX.
Seemed like cost was a factor more than time here though unless I misread.
Personally I’d use foam board and be ready for a flood test by noon, but not everyone wants to pay for that.
Different on a job than diy (isn’t that the case here?) where labour is “free” so to speak
Old 03-08-2018, 09:49 PM   #8
usedsoup
Thanks everyone, I think I'm sold on the Durock membrane over drywall.
On top of that I called a Tom Duffy supply house here in town and its only $70 for a 25' roll
Also anyone on this board in the Phoenix area?
I'm trying to find a good glass installer.
Nate
Old 03-08-2018, 10:12 PM   #9
From what I can tell, only two companies have paid for the tests to certify their sheet membranes will work over drywall - Schluter and Laticrete.
So, since that is required to actually be considered a valid installation, you could be in for problems. I'm not saying it won't work, but if an inspector actually knows and understands the stuff, it could fail because it wasn't installed per the instructions over a certified backer.
Shower Pan Waterproofing - Which method? JeffeVerde Tile Forum/Advice Board 0 08-02-2012 12:56 AM
Shower Mod – Divot Method using Hydro Ban Waterproofing AZKIDD38 Tile Forum/Advice Board 8 07-14-2011 10:18 PM
How to decide which waterproofing method? miamicuse Tile Forum/Advice Board 3 01-03-2011 09:14 PM
Method of Tiling Wall and Waterproofing? cb9209 Tile Forum/Advice Board 25 09-03-2010 06:02 AM
Not sure what method to use for my shower AndyFL Tile Forum/Advice Board 7 02-05-2009 01:31 PM
