Old 03-06-2018, 09:32 AM   #1
jedf
Bathroom Tiling - unglazed porcelain tiles
Hello - what a wonderful resource! Seeking some expert advice...sorry in advance for the many questions but I just want to make sure I do this right (only other tiling experience was last summer with large format porcelain tiles in the entryway).
I am installing 2" x 2" hexagonal porcelain tiles (unglazed) over DITRA in a bathroom (floor inside and outside the shower).
1. When you're grouting rectangular or square tiles, you pull the grout float diagonally across the tile...which direction do you run the grout float for a six sided tile??
2. Should I seal the top of the unglazed tiles? The tile showroom sales person said no, but the tile person at the big box orange store said yes. The tile is a darker gray...
3. Related question - whether or not I seal the unglazed tiles, should I put down grout release? And if so, how bad is it if grout release gets into the joint lines? I am trying to understand if I need to meticulously hit the top of every tile with something small and precise (toothbrush?) or if I can "mop" the whole floor with grout release.
4. Should the grout on the floor match the grout on the shower walls?
JF
JF
jedf is offline   Reply With Quote
Old 03-06-2018, 09:45 AM   #2
Hi JF,
I don't pre-seal unglazed porcelain tiles, but some do.
Grout release should not go into the joints.
Experiment with the float direction.
Want "wet look" on unglazed porcelain tiles storm0959 Cleaning, Restoration and Sealing 5 03-25-2011 01:04 PM
experience with 1" hex unglazed/matte porcelain tiles? wowthatsnice Tile Forum/Advice Board 1 01-12-2007 02:38 PM
help with unglazed porcelain tile mwitter Cleaning, Restoration and Sealing 1 08-16-2006 07:43 PM
HELP ! Grout left on unglazed porcelain tiles too long ! Christopher1963 Tile Forum/Advice Board 9 06-11-2004 08:55 PM
Glazed or unglazed porcelain? maggie625 Tile Forum/Advice Board 3 02-20-2004 08:48 PM
