Old 03-05-2018, 03:02 PM   #1
Tub surround
Doing my first major bathroom remodel in years. I will finally break down and buy the e-books here, I really need to sharpen my game.
My immediate question is about sheetrocking the room. The wall, up against which the long back side of the tub will sit, is below grade (in the half-basement, house on a hill). Just removed the old shower (room is doubling in length, or width rather, going to borrow room from the prior family room, now my client's largest rented room).
The framing on that wall is 2x4s flat against, or close to, the concrete. Going to put in the 1.5 inch solid foam insulation. The tub is porcelain clad thin steel. Everything I've seen so far, and over the years, is to attach the tub up against the bare studs. My thought is to put the purple/green rock down to the floor and then proceed as if it was still bare studs. Would then put the concrete board down to the lip and the tile down to 1/4" about the upper tub shoulder.
I just cant see any value in putting the rock down over the lip. I mean, sure, it's water resistant but still.
But would this be overkill? Should I instead just put concrete board over felt against the studs? My thought was that the rock would help to ensure the insulation of the foam board. We're taking the tile to the ceiling, three sides.
cmac2012 is offline   Reply With Quote
Old 03-05-2018, 07:07 PM   #2
Having the tub go against the studs will allow the cement board to finish out further over the tub lip. Sometimes this is helpful, especially on the two end walls when the framed opening is a little wider than needed.
Can you install the CBU over the tub in place of the greenboard?
The best way to fix a tub surround. jrid Tile Forum/Advice Board 6 02-08-2010 06:49 PM
Jon's tub surround Jonnycat Tile Forum/Advice Board 24 12-03-2009 10:38 AM
Need Help with Tub Surround todd1 Tile Forum/Advice Board 3 09-04-2006 12:08 PM
Tub Surround ziggy96 Tile Forum/Advice Board 1 05-31-2006 03:34 PM
tub surround dougwilliams Tile Forum/Advice Board 3 03-25-2005 09:50 AM
