Old 03-04-2018, 07:30 PM   #1
Blavery
Kerdi Drain foam spacers
Hello, Iím about ready to install my Kerdi drain and noticed that the included styrofoam spacers only get the drain 13/16Ē above the subfloor. The instructions indicate a minimum thickness of 1Ē of mortar at the bonding flange. Am I missing something here? I suppose I can easily add some height to the spacer, but why the inconsistency. Even if I flip the styrofoam, itís still 13/16Ē. (Spacer is symmetrical). Should I follow the spacer height or the instructions? Odd that they would include precut spacers that donít get the drain at the proper height.
Blavery is offline   Reply With Quote
Old 03-04-2018, 07:33 PM   #2
Welcome to the forum, Brian.
Are you over a wood subfloor or concrete?
If concrete, I'd have no problem going with the spacers. If over wood, then set it up to 1 1/4" or more.
Old 03-04-2018, 08:07 PM   #3
Blavery
Kevin, Iím going over 3/4 plywood subfloor.
Old 03-04-2018, 10:25 PM   #4
Set the drain flange at a minimum of 1 1/4" off the subfloor.
Old 03-05-2018, 10:49 AM   #5
Hi Brian,
I think Kevin is thinking you're going to make your own floor from mortar. If you are using the Kerdi foam tray you don't want the drain any higher than the spacer.
Old 03-06-2018, 09:51 PM   #6
Atomic21
I asked the same thing a month or two ago! I think the syrofoam spacers are made to be placed on top of wire mesh...giving you that extra little bit to achieve 1" from the top of subfloor to b/flange.
John
Atomic21 is offline   Reply With Quote
kerdi foam shower tray over OSB JMG Tile Forum/Advice Board 68 05-09-2018 06:11 PM
Various ways of using schluter/Kerdi foam board Autoplay The Mud Box 2 12-21-2016 07:35 PM
Kerdi foam curb not level left to right Mister Tall Tile Forum/Advice Board 6 11-02-2012 09:17 PM
Kerdi Foam Shower Pan Adhesive Question vtcrusade Tile Forum/Advice Board 6 12-30-2010 11:05 AM
Kerdi Foam Base Question: bbh03 Tile Forum/Advice Board 4 07-06-2005 09:26 AM
