Old 03-04-2018, 12:47 PM   #1
Mr Hunter
I messed up - Ditra Confusion
Hello,
I think I messed up and used modified thinset over ditra to set porcelain tiles.
How bad is this? Does it just need extra drying time?
Hunter
Mr Hunter is offline   Reply With Quote
Old 03-04-2018, 01:04 PM   #2
Redlands Okie
lots of time to dry
Robert
Redlands Okie is online now   Reply With Quote
Old 03-04-2018, 01:54 PM   #3
I do it all the time to make sure the thinset bonds well to the porcelain tiles. Like Robert says, allow an extra few days to dry and keep the heat on in the room.
Old 03-04-2018, 02:06 PM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
Lots of time to dry and damn to hell with the warranty!
You will be fine.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Old 03-04-2018, 03:18 PM   #5
Not all modified thinsets are alike. Some modifiers will work well, some won't. Some will become stable while still wet, some won't (generally, those that use latex as the modifier won't be stable until they dry). Porcelain won't really allow moisture through it anytime fast, neither will Ditra, so the only place it can evaporate from is the edge, and with some modifiers, they make it really hard for moisture to migrate to the grout joints. In the worst case, with a large format tile, it could literally take over two months for full drying. Things should be fairly stable prior to that. The cement will cure, but if the modifiers aren't stable, the crystals of cured cement can shatter at a microscopic level.
So, depends on what exactly you used and how much you stress the floor, how dry the air is so moisture will evaporate faster (a fan and heat can help).
Old 03-05-2018, 06:36 PM   #6
Mr Hunter
Thanks for your help. This makes me feel way better.
Now, if installing tile over painted drywall on a wall in a dry area, modified thinset?
Hunter
Old 03-05-2018, 06:44 PM   #7
Yup.
Old 03-05-2018, 10:06 PM   #8
Thinset will stick to most paint used in a home, but there's no guarantee that that might not cause the paint to come loose from the wall. If it's a gloss, scuff it up and clean off the dust.
May have messed up - SLC & DITRA over plywood RRBartlett52 Tile Forum/Advice Board 2 01-04-2016 04:53 PM
messed up my ditra miac Tile Forum/Advice Board 5 08-19-2012 02:45 PM
Messed up & used unmodified under Ditra PeteCT Tile Forum/Advice Board 2 04-23-2011 04:43 PM
Ditra Thinset Confusion Duane Tile Forum/Advice Board 34 06-25-2007 11:13 PM
confusion about Ditra jmc Tile Forum/Advice Board 3 03-30-2004 05:53 PM
