Old 03-03-2018, 10:00 PM   #1
sofr2131
Finishing off tile cut as baseboard
12 x 24 tiles are cut as baseboard. How can I finishing off the tops? Tile store recommended a stone pencil tile however Im having second thoughts as the pencil tile is not exactly the right color. Can a silicone caulk be used in a color that matches the grout?
Sissy
sofr2131 is offline   Reply With Quote
Old 03-03-2018, 10:43 PM   #2
Gozo
I did exactly that in two bathrooms. Looks fine and even the missus (whos more than just a bit critical) hasn't made any comments. It just blends in. I made a tooling tool from a scrap piece of plastic that forms the silicone into a shallow wedge over the top edge of the tile. Not making a mess with silicone took some practice for me, so give it a few goes with some generic silicone as a test before using the color matched stuff on the real deal.
Jeff
Old 03-03-2018, 10:52 PM   #3
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
i do lots of tile skirtings, i finish the top with a tile trim....
Jim
Jim Farrell Tiler is offline   Reply With Quote
Old 03-03-2018, 10:54 PM   #4
Jim Farrell Tiler
better pic to see trim, i didnt pick the ugly tile...
Jim
Old 03-04-2018, 03:23 AM   #5
This is precisely the reason there are profiles made for tile. At least a few companies make them, but the largest selection is probably from www.schluter.com. Caulk can work as well as can profiling the edge with a tool if it's a through-body porcelain. Depends on the look you want to achieve.
Old 03-04-2018, 05:27 AM   #6
Just In Tile LLC
Just In Tile LLC's Avatar
Another vote for tile trim, really gives that professional finished look
Justin
Just In Tile LLC is online now   Reply With Quote
Old 03-04-2018, 03:42 PM   #7
Many of the tile edging profiles are not very flexible, so if your wall is not flat, the tile will still be up against the wall, but the profile will not. Check your wall first with a long straightedge, or you may be disappointed. It works really well when the surface is flat, though.
Baseboard over tile or tile to baseboard? Hendo Tile Forum/Advice Board 2 10-23-2007 02:31 PM
TILE and BASEBOARD Rob10737 Tile Forum/Advice Board 14 10-01-2007 08:31 PM
Tile Baseboard tbrim Tile Forum/Advice Board 13 01-18-2007 06:58 PM
Tile baseboard DanDan Tile Forum/Advice Board 2 11-21-2004 05:20 PM
baseboard tile jebb Tile Forum/Advice Board 3 02-29-2004 12:01 AM
