Old 02-25-2018, 09:30 PM   #1
fulms
Spectralok Pro and glass tile
I'm laying some porcelain tile in my master bathroom and the boss (wife) wants the border inlayed with some glass tile. I wanted to use Laticrete Spectralok Pro grout because I like the epoxy for the shower and its good stuff ive used it before but never with glass. Any worry about that scratching the glass? Anyone use it with glass with good results?
Mitch
fulms is offline   Reply With Quote
Old 02-26-2018, 01:55 AM   #2
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
i used it in my ensuite and it scratched the trims so i wouldnt use it on glass
Jim
Jim Farrell Tiler is offline   Reply With Quote
Old 02-26-2018, 04:23 AM   #3
tilemanct
Tile & Stone
When will this glass tile thing end!! Great for windows, not so great for tile. Unfortunately you will have to do a mock up and do a test with the SpectraLock . Better to find out it scratches on the test sample rather than having to rip out the border.
One other option is Mapei's 3D Flexcolor Grouts for Glass Tile.
If you do wind up using the SpectraLock, make sure you have some expansions for that glass tile.
CTEF Certified Installer
Old 02-26-2018, 08:14 AM   #4
RichVT
Vermont Remodeling Contractor
I used Spectralock Pro Premium on this shower. No scratching but I DEFINITELY did a test board first and caulk at all edges and changes of plane.
Rich
RichVT is offline   Reply With Quote
Old 02-26-2018, 05:41 PM   #5
Karls tile Inc
Tile and stone contractor Tile setter
Outstanding work!
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 02-26-2018, 08:37 PM   #6
mullet
mullet's Avatar
Rich, that is top shelf work!!!
chuck
my first Kerdi Shower
Old 02-27-2018, 02:38 AM   #7
tilemanct
Tile & Stone
Nice job. Noticed all plumbing centered in tiles. Did you do an amazing layout or did you tile first, then rough from behind?
Old 02-27-2018, 08:28 AM   #8
RichVT
Plumbing definitely went in first. I think I just got lucky on the layout. I did make sure that the valves were in a perfect level line.
Niches are the premade Kerdi Board niches and were padded with scraps of Kerdi Board as needed to match the tile size. They were installed after I started tiling. And yes, I did put Kerdi Band around the niche after the second photo was taken.
This job is the master bath in my own house so time was no object. I think it was 2 1/2 years from start to finish working on it when I had free time between other jobs.
Rich
Old 02-27-2018, 10:16 AM   #9
Sharon @ LATICRETE
Sharon @ LATICRETE's Avatar
I would agree with the tilemanct. We have used it on glass and it did not scratch, but it all depends on the glass. A test area will confirm suitability and acceptability for the material you are working with.
Sharon@LATICRETE
Sharon @ LATICRETE is offline   Reply With Quote
Old 02-27-2018, 12:01 PM   #10
dhagin
Make a test board with some extra pieces during installation, then test with part c only before grouting. Set the test board on a piece of clean plastic so you can collect & dump the "test" part c back into the container. We've installed much glass with spectralock and we test each time. Never had one scratch yet.
dana
Old 03-02-2018, 09:55 AM   #11
fulms
Ok thanks all and good advice about the part c only! I'm sitting here thinking ill have to mix a mini-unit just to see if it will scratch. Never thought to just use part C
Also I have two bags of 253 gold thinset left from the last job. It was 6x24 hardwood look tile. This is going to be used with a 12x24 wall tile in a shower. Sharon can you comment is 253 gold ok to use with this large of a tile. It doesn't have a limitation on the data sheet.
Note: I don't really like 254 platinum cuz it has ruined to many pairs of pants and is not as nice to play with. ha
Mitch
Old 03-04-2018, 06:21 PM   #12
NEPA Remodeling
Custom Home Remodeling
Spectralok is my go to grout. I have tried others such as flexcolor and bostik, but I always end up going back to epoxy for improved performance.
I have used it a few times with glass without a problem, but as others said, test it first with a mini unit.
Nice work on that shower, Rich. I too wait until I start setting tiles to cut in the niches. It allows for perfect coordination!
NEPA Remodeling is offline   Reply With Quote
Old 03-05-2018, 11:30 AM   #13
Sharon @ LATICRETE
There is no problem using 253 Gold for this application as long as it is used as a thin-set and not a medium bed mortar.
Sharon@LATICRETE
Old 03-09-2018, 08:09 AM   #14
fulms
Yes it will be used just to set the tiles.
Thank you Sharon!!
Mitch
Freezing SpectraLok Pro Grout? wrk2891 Professionals' Hangout 4 06-29-2010 01:30 PM
Used spectralok on tub surrount .. when can the shower be used? tombstone Tile Forum/Advice Board 4 08-16-2008 11:16 PM
Old Spectralok? larryinseattle Tile Forum/Advice Board 6 10-16-2007 08:19 PM
Spectralok help for my installer Mba Tile Forum/Advice Board 1 03-16-2006 06:28 PM
SpectraLok moneypit Tile Forum/Advice Board 22 10-14-2003 06:40 PM
