Old 02-21-2018, 07:09 PM   #1
jwmezzanotte's Avatar
Travertine wet area
Customer looking at a filled and honed travertine from Home Depot for the walls of their shower. The pan will be a porcelain tile matching the rest of the floor (curbless shower)
Any horror stories with this material in a shower? I don't want to use slate (not real comfortable with white marble either) in a shower, but have not personally had trouble with travertine. Hydroban board shower.
I've got some 511 penetrating sealer from miracle sealants.
Old 02-21-2018, 08:58 PM   #2
It takes more maintenance to keep a stone tile clean. Acidic cleaners work well on ceramic and porcelain but can't be used on stone. So it takes a lot more elbow grease with mild cleaners to keep the stone clean. If you let the soap film get out of hand, it's very hard to clean. I've installed hundreds of stone showers but I wouldn't want the maintenance that goes along with stone. My showers are ceramic.
Old 02-22-2018, 04:43 AM   #3
Tile & Stone
Bad idea. The quality of the stone at HD is usually bottom of the barrel. Lots of maintenance. There are so many porcelain tile "travertine" look-a-like's that there is no reason to use the real stone. Less headaches and extreme longevity!!!
CTEF Certified Installer
Old 02-22-2018, 09:39 AM   #4
If that's what the customer wants . . .
Honed travertine can be maintained. I recommend all tile showers be hand dried with a towel after use. If that's done the travertine will work.
Old 02-23-2018, 05:55 AM   #5
I agree that white marbles and most limestone are a bad choice for shower or wet areas. .Travertine can work depending on the type of travertine..But maintenance and installation is the key
Frederick M. Hueston
office 321 514 6845
Stone Inspection and Troubleshooting seminar June 11-14, Melbounre FL
For more details see the training section at www.stoneforensics.com
check out the Stone and Tile Radio Show at http://www.blogtalkradio.com/drfred New show starts February 21 at 6pm EST
Facebook https://www.facebook.com/stoneforensics1
fhueston is offline   Reply With Quote
Looking for Tampa area travertine crack repair amheck Cleaning, Restoration and Sealing 1 12-29-2012 02:20 PM
Area rugs on travertine REGAS Tile Forum/Advice Board 2 10-22-2011 09:14 AM
Is this right for travertine in the tub/shower area? smschulz Tile Forum/Advice Board 38 03-11-2008 05:47 PM
Travertine Pallets for Sales? (Miami Area) JDiaz Tile Forum/Advice Board 5 12-30-2007 05:23 PM
