Old 02-19-2018, 08:59 AM   #1
jtraggie99
Dallas Area (Plano) Tiler Needed
I have a friend in Plano who has a second floor shower that is leaking. They noticed a small water stain on the ceiling below and called out a plumber. The plumber cut a small hole in the ceiling to check for leaks and could find anything. Their initial thought was it might be a roof leak and water was getting down the walls and to check for water the next time it rained. After some trial and error, they discovered that it seems to happen when water hits a crack toward the floor (not on the floor). Sounds like a shower pan issue to me.
Anyway, just looking for someone in the area that can help her. Thanks!
Jason
jtraggie99 is offline   Reply With Quote
Old 02-20-2018, 10:58 AM   #2
Hi Jason. Did the plumber plug the drain and fill the shower? It's best to use water from somewhere other than the shower head. Even a few gallons poured into the shower might be enough to get it to leak below if it's the pan leaking. I would avoid pouring water in a crack that's on the wall. That water might be getting behind the pan and not testing the pan at all. If it leaks below from pouring water on the shower floor, it's the pan.
Have him call me and we can talk about it. 972-841-6190
Old 02-20-2018, 12:22 PM   #3
jtraggie99
Thanks Davy. I passed along your suggestions and also your info to them. I appreciate it!
Jason
Looking for someone to work in the Dallas area JohnB Texas Professionals' Hangout 4 07-23-2017 09:38 PM
Tile setter in Dallas/FW area needed bka Professionals' Hangout 8 05-05-2008 06:11 AM
Someone needed in Dallas/Fort Worth area Janet S Cleaning, Restoration and Sealing 13 02-17-2007 03:00 AM
Dallas TX Area Pro Needed Hans47 Professionals' Hangout 1 02-19-2006 08:31 PM
