Old 02-15-2018, 11:22 AM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Concrete dust collection. What do you use?
Hi guys. I was asked if i wanted to remove about 1200 feet of tile. I don't really want to do it but i think i cant pass up the money.
I usually don't tackle tear outs of this size and am not set up to capture this amount of thinset/ concrete dust. My current setup is an 8 inch grinder with a dust shroud, and a shop vac.
Looking for recommendations for prefilter or dust separator. I have seen a few basic designs and could make one. Thinking about a 40+/- gallon rubber made trashcan on wheels with an intake/ exhaust built in to it. Would also consider spending a few hundred dollars on real one.
Any suggestions or recomendation? My stoner buddy suggested a bubble filter of some type but i don't think i want to deal with a huge chunk of concrete mud when i need to dump it. Or maybe i do?
I pulled up a few tiles when i first looked at it. They come up easy and leave a solid 1/8th to 1/4th of thinset stuck to the concrete. The house is empty and a little dust in the air isn't as issue.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 02-15-2018, 04:58 PM   #2
Simplyjames
Simplyjames's Avatar
Air scrubbers can be pricey. I have in the past just used well placed fans and air movers along with strategic opening of windows. Maybe skip the grinder too. Ive usually been able to have good success using a simple razor scraper. Id rather burn through several boxes of blades than churn up all that silica.
Whatever you do, remember to mask up.
James
ACT certified installer #015
californiaflooringltd.com
Simplyjames is online now   Reply With Quote
Old 02-16-2018, 01:43 PM   #3
dhagin
There's. extensive discussions about that here. Think a combination of tools with proper duct collection design, specially designed hi cfm vacs, air cleaners /scrubbers, and temp walls. Demo & prep have different requirements, so these may not all be needed.
The initial investment is somewhat hi, but necessary to do it properly & safely.
dana
Old 02-16-2018, 03:20 PM   #4
Just In Tile LLC
Just In Tile LLC's Avatar
I use the dust deputy and connect them to my tools, fan in a window and plastic over rooms doors that have furniture. Won't start still I feel a draft from masked off spaces meaning I've created the negative pressure to keep any escaping dust from flowing into places I don't want. Turn off AC so it doesn't compete for air intake. Usually tape off vents and any fixtures I can reach.
Pretty cool DIY dust collection I saw for a demo hammer was a flex gutter drain hose n with a 2" pvc fitting. Heat the pvc up with torch or heat gun and template your vac hose to it.
Another cool design I saw work was basically a bong using said 2"pvc and water bucket with a lid. Hose gets connected to side of the bucket at an angle so water stays out of the house, and intake to the vac was at the top. All air travels through the water
Justin
Old 02-16-2018, 06:21 PM   #5
Shady at Best
Tyrone shoelaces
Thanks for the replies. I have seen the dust deputy. I think i will rig something like that up on a medium sized trash can
Travis
Old 02-17-2018, 06:14 AM   #6
tilemanct
Tile & Stone
Contact Oneida and purchase a unit for a large drum unit or get the commercial unit. Don't screw around trying to jury rig something. The cost of a professional cleaning crew to clean up your dust will be way more than the price of a Dust Deputy and a good Air Scrubber. Believe me...I know.
Also..have you priced a new set of lungs lately?
CTEF Certified Installer
dust collection set Professionals' Hangout 6 04-27-2014 10:29 PM
Dust collection John K Professionals' Hangout 8 07-09-2007 06:51 AM
To add to the collection....My Gripe! michaelhazuka Professionals' Hangout 20 07-16-2006 02:34 PM
dust collection madmax Professionals' Hangout 2 04-28-2005 10:10 PM
