Old 02-11-2018, 09:24 PM   #1
lati_cz
michal
replacing floor tiles
I have to move toilet flange. It involves cutting out 2 tiles, I have 2 tiles extra and I have no idea where tiles were purchased.... I have steady hand (grinder), but I am bit nervous having no extra tiles. Any tricks?
Michal
lati_cz is offline   Reply With Quote
Old 02-11-2018, 09:50 PM   #2
Just In Tile LLC
Just In Tile LLC's Avatar
If you can't reuse the ones you pop out (if they come out well or because they are the current toilet cuts I'm guessing) the only trick I know is to cross my fingers
I do use a variable speed grinder which does help in some cases to slow the blade rotation and vibration.
Justin
Old 02-12-2018, 08:00 AM   #3
evan1968
Not So Senior Contributor
evan1968's Avatar
Lay off the coffee before hand.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Replacing Tiles over Heated Floor JennTile Tile Forum/Advice Board 3 09-19-2007 08:47 AM
Replacing 50 yr old 9" floor tiles davidg77 Tile Forum/Advice Board 2 08-24-2007 05:57 PM
Replacing tiles rugman8 Tile Forum/Advice Board 2 01-18-2005 07:00 PM
Replacing tiles Brad Miller Tile Forum/Advice Board 5 03-11-2004 04:15 PM
Replacing tiles wdh010 Tile Forum/Advice Board 8 10-20-2001 02:25 PM
