Old 02-11-2018, 11:52 AM   #1
SelmaElias
Difference b/w impregnator & penetrating sealers?
Hello
Im wondering if there is a difference between impregnator sealers and penetrating sealers. I just had basic ceramic subway tile installed in my shower, with light grey, non-sanded grout, and I now need to seal the grout (at least I think I do). I read on one site impregnator sealers will darken grout color more than penetrating sealers. Is this true? On another site, I read impregnator and penetrating sealers are the same thing. Im a little confused, so I turned to this helpful forum. I love the current color of the grout now, and would like to avoid darkening, if possible. Any suggestions on what product and brand I should use to minimize darkening of grout? Thank you in advance.
Kelly
SelmaElias is offline   Reply With Quote
Old 02-11-2018, 04:15 PM   #2
stu rosen
They are the same-to be an impregnator it has to penetrate. Their are many different formulations made today that will have different rates of penetration based on the product and the surface your trying to protect. Sealers can react differently at times so its best you test yourself. For grout lines a solvent based carrier may work better. Any brand name will be fine-so many to chose from.Your subway tiles aren't porous but the grout doesn't hurt to seal-when you think about it what will stain the grout on your shower walls.As far as the shower floors, any staining there will come from soap film and or moisture. Sealers have their place for sure just slightly over rated.
Stu
www.stoneshine.com
stu rosen is offline   Reply With Quote
Old 02-11-2018, 04:38 PM   #3
SelmaElias
Thank you for your insight, Stu. Yes, I don't need to worry about staining. It's a shower/tub set up, so I'd only be sealing the walls. I thought I would need to do this to help increase water resistance, and therefore reduce water from penetrating the grout. Are you suggesting sealing for water resistance might not even be necessary? Just curious ...
Kelly
Old 02-11-2018, 05:34 PM   #4
Over rated is exactly right. Most people think that if they seal tile and grout, it'll block all moisture and stains. In a kitchen, the sealer will usually give you time to get a spill cleaned up before staining happens. You can seal your shower if you want but the waterproofing is, or should be behind the tiles.
Old 02-11-2018, 05:58 PM   #5
SelmaElias
Thank you both so much. If I'm understanding you correctly:
- repeated water exposure to unsealed grout doesn't mean the grout will dissolve overtime (or lead to mold issues).
- it doesn't matter if water soaks the grout because most of the waterproofing efforts are taking place behind the tile.
Correct on both?
Sorry for my ignorance.
THANK YOU!!
Kelly
Old 02-11-2018, 06:57 PM   #6
Correct. Grout will turn dark when it gets wet, some colors more than others.
It's not normal for grout to dissolve just from water exposure.
Having plenty ventilation helps dry the bathroom out and less chance of a mold problem. Like Stu said, soap film is where mold likes to grow so keeping it clean helps.
Old 02-11-2018, 07:02 PM   #7
SelmaElias
Wonderful, thank you again.
Kelly
Wrimco or other waterproof penetrating sealers? A Smith Cleaning, Restoration and Sealing 1 07-28-2015 07:17 PM
Miracle Sealants 511 impregnator or Aqua Mix Sealers Choice Gold? Altfineart Cleaning, Restoration and Sealing 24 09-05-2012 12:22 PM
Generic Preferences for Penetrating Stone Sealers MDS Cleaning, Restoration and Sealing 0 01-25-2012 09:14 AM
Penetrating Travertine sealers????? unvrknw Tile Forum/Advice Board 2 10-26-2004 06:45 PM
True penetrating concrete sealers/strengtherners rjb Professionals' Hangout 34 01-08-2004 01:55 PM
