Old 02-18-2018, 03:30 PM   #16
I'm pretty sure direct wire to the Halo HU10 fixtures is from the side only, and that requires NM cable or what they call 5/16" flexible metal conduit. At only 3/4" deep, the KO on the side is some small size I'm not familiar with, looks like it can only be 1/2" or so in diameter. You might be able to get a right angle connector to use with the so-called 5/16" flexible metal conduit, but I'm not sure if they come that small.
They do make a splice box that has a KO in the back (not sure on the size), so that would work but would take up some running length that could be lights. Also, I was a little surprised that for daisy chaining, the shortest connector they have is a rigid double male that they call a 1-1/2" connector. Presumably that means it leaves a 1-1/2" gap between fixtures.
Cheers, Wayne
kitchen cabinet question Lighthouse1953 Tile Forum/Advice Board 10 05-23-2010 11:53 PM
under cabinet lights sophia449 Tile Forum/Advice Board 9 03-11-2006 08:19 PM
How to tie-in backsplash under kitchen cabinet Stuart P. Tile Forum/Advice Board 10 04-22-2005 08:21 PM
Tile to or under medicine cabinet and lights SteveO DIY Tile Forum/Advice Board 4 09-12-2002 07:22 PM
