Old 02-08-2018, 12:11 PM   #16
Obo2
for plywood you want exterior grade glue.
it should be labeled bcx or acx not sheathing and not pressure treated.
HD and lowes will do some basic cutting for you to be able to get the supplies in your vehicle or it's like $20 for the hd truck if they have them.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 02-08-2018, 01:10 PM   #17
jtaylor1975
Thanks Nick. The size issue isn't just for transportation reasons...I'm a 5 foot nothing gal and moving a whole sheet of plywood myself is a little outside my range of capabilities
Jenny
jtaylor1975 is offline   Reply With Quote
Old 02-08-2018, 01:33 PM   #18
Obo2
do you even lift bro?
I'm 6'2 and a full sheet of plywood is one of the most awkward things i have ever picked up.
I would try to keep the pieces as large as needed to minimize seems though.
screws should be every 4" on the edge and every 6" in the field. I like to predrill with countersink bit only through the ply to keep everything nice and flat.
Nick
Old 02-08-2018, 04:26 PM   #19
jtaylor1975
I do lift but I don't think you're talking about my puny 10 lb curls
You should have seen me trying to wrangle two sheets around my kitchen when I was making some laminate countertops last year...
Back to the "real" topic...what kind of screw pattern do you recommend for the part I will be replacing? 4 inches? longer? shorter? These will be screwed into the joist.
So for the ply, I'll be screwing 3/4" ply into 1" planks...1 1/2" screws?
Think I'm gonna start working on my wall layouts tonight...heaven help me
Jenny
Old 02-08-2018, 05:37 PM   #20
Obo2
I believe 6 " spacing is plenty for the subflooring. You'll also want to glue to the joists.
You'll want your screws to fully penetrate the subfloor so go with 1 3/4ths or 2" and use decking screws not drywall screws or something.
Nick
Old 02-08-2018, 06:45 PM   #21
jtaylor1975
At the 1 3/4" or 2" length I'm gonna have a bunch of screw tips sticking through the floor eh? Though I'm sure it will look interesting looking up from the basement is that ok?
Jenny
Old 02-08-2018, 06:52 PM   #22
jtaylor1975
Oh yeah, onto the walls...I'm gonna be skim coating them this weekend and hopefully getting the tile on them the next. I wanna buy my supplies this week while Menards has its "rebate" week. I'm gonna be doing 3x6 white subway. What should I use to stick em to the walls? I'm also doing a row of glass mosaic near the top. What kind of grout should I use?
Jenny
Old 02-17-2018, 07:02 PM   #23
jtaylor1975
I'm baaaack!
Just about done with the wall prep...FINALLY. Took too long to get the hole cut for the medicine cabinet...*sigh*
Now that I'm making some forward progress...Do I tile before I hang the medicine cabinet or after? Will also be installing a small cabinet above the terlet...
Also, bought modified thin set for the wall tile...should I have bought unmodified? There was really nothing at the store that said "unmodified" but have since learned it's also called "dry set" which they do have...
Jenny
Old 02-17-2018, 08:11 PM   #24
Hi Jenny, it may not matter which is installed first. I like the look of the medicine cabinet over lapping the tile but that's up to you.
I'd use white Modified thinset.
Old 02-17-2018, 08:17 PM   #25
jtaylor1975
Thanks Davy!
The tile is going to go up about 15 inches from the bottom of the cabinets. The only thing I'm worried about is it being flush with the wall if I lay it on top of the tile. But I could caulk that maybe?
Jenny
Old 02-18-2018, 11:36 AM   #26
If I understand you correctly, the tiles aren't going all the way around the medicine cabinet, only up to it at the bottom. If that's the case, I would set the medicine cabinet first and tile to it if that's possible. Just depends on the design of the medicine cabinet.
Old 02-22-2018, 07:38 PM   #27
SageHome
Any concern about possible asbestos in your bathroom?
I ask because I went through a nightmare last year with a contractor who didn't have a license removing asbestos tile in my kitchen.
So when I hired a new contractor to redo my bathroom, I made sure they were licensed.
I had my 1950s plastic tiles on wall and floors but other people said they didn't have any asbestos.
Turns out everything tested positive, even the wallpaper and glue beneath the newer (lat 1950s) wall tile.
Peter
SageHome is offline   Reply With Quote
bathroom project fmfmedic Tile Forum/Advice Board 2 04-13-2011 02:14 PM
Ame's Bathroom Project crust Tile Forum/Advice Board 54 04-10-2011 12:14 PM
New Bathroom Project Rob13 Tile Forum/Advice Board 4 07-08-2010 12:41 PM
Ray's Bathroom Project RMok1111 Tile Forum/Advice Board 18 10-19-2008 08:31 PM
Tom's Bathroom Project tbrim Tile Forum/Advice Board 38 02-07-2007 09:06 AM
